Old 05-22-2017, 06:01 PM   #21
JSeery
JSeery's Avatar
Default Re: fuel push rod insert
I plug them with a press fit pin. This pin was for a 59a block, for an 8ba you would want to be sure the pin was long enough to cover the hole.
Old 05-22-2017, 10:14 PM   #22
51 MERC-CT
51 MERC-CT's Avatar
If I were making a bushing plug for an 8BA bushing (to accommodate electric fuel pump use ) I would not totally plug the oil supply hole in the bushing.
Leave the same push rod to bushing clearance on the lower end of the plug to allow the cam bearing to be lubricated as I believe Ford intended.
Old 05-23-2017, 12:13 AM   #23
pooch
pooch's Avatar
Is there no hole between the rear main and rear cam bearing for oil to push up ?
pooch is offline   Reply With Quote
Old 05-23-2017, 09:01 AM   #24
51 MERC-CT
51 MERC-CT's Avatar
No, the oil is pushed down from the oil galley tube to the front and center cam bearings and on to the front and center main journals.
The rear cam bearing looks to be lubricated by residual oil passing between the oil pump and the oil pump bore plus any splash or vapor that gets into the idler gear chamber. The rear cam bearing does not see any pressurized oil.
The rear main is lubricated by a port from the oil pump to the bearing.
Thread Tools
Display Modes
