08-07-2022, 03:34 PM | #1 |
install model B 4 cyl. into model A ?
I have a very good model B 4 cylinder motor and syncro transmission that I would like to install in my 31 model A coupe.
The model B set-up I have is a complete motor with transmission, however I notice there is no brake pedal assembly like there is on the model A set-up. Can any of you experienced guys tell me what I need to obtain or how I can make the conversion. ? is there a pedal kit ? who would sell it ? What other things would I have to think of that is not obvious ? |
08-07-2022, 03:58 PM | #2 |
Re: install model B 4 cyl. into model A ?
Conversion kits have been available, check some of the supply houses. I think A&L put them together.
08-07-2022, 05:44 PM | #3 |
Bert's used to have the kit but I don't think they have it any longer.
08-08-2022, 12:43 AM | #4 | |
Charlie Stephens |
08-08-2022, 03:14 AM | #5 |
The bolt holes in the flywheel housing are in a different place also. using a B float a motor kit solved this, but I think the availability is now in question.
08-08-2022, 08:02 AM | #6 |
2. The last that I heard, Berts manufactures and sells the kit for MODEL B transmissions. This is the kit originally developed by AC&R Inc. At least this was the case before Covid 19. Last edited by Benson; 08-08-2022 at 08:27 AM. |
08-08-2022, 10:47 AM | #7 |
Send me an e-mail and I'll send you the chapter of my book about this. [email protected]
08-08-2022, 09:17 PM | #8 |
Search this forum for B engine in a model A frame there is a wealth of inf on here just finished mine. good luck
08-09-2022, 01:15 PM | #9 |
Bert's Part Nr. A07002
