Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 07-02-2022, 09:37 AM   #1
sonnybrown
Default 6 cyl 47 ford truck won't start
complete tune up including condenser, points, wires, cap & rotor. Gets good spark, gets fuel (looking down top of carb and moving accelerator rod) adding gas in carb and either. To no avail, I just won't fire. Plugs seem dry as if no fuel getting in even when adding a couple ounces of gas down carb. Check times on compression stroke on # 1 cyl to location of rotor as is ok. The engine makes no attempt to fire. This was a running engine that wasn't started for a couple of weeks. Suggestions?
sonnybrown is offline   Reply With Quote
Old 07-03-2022, 09:17 AM   #2
redmodelt
redmodelt's Avatar
Default Re: 6 cyl 47 ford truck won't start
Suggest asking on the Early V8 section. This section is for questions about the site and its use, not car questions.
In the meantime, do a compression check. Might be stuck valves.
