Old 03-27-2022, 08:11 AM   #1
Steves46
Steves46's Avatar
Default Fuel Shut Off Valve
Hey guys, I recently switched over to a single down-draft intake with a Stromberg 97. Since my gravity feed is traveling down to the electric fuel pump on the frame, should I still open/close the fuel shut-off valve inside the car or would it be ok to leave it open now? I think it would be since I am using an electric pump but wanted to be sure. Thanks.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 03-27-2022, 10:32 AM   #2
katy
katy's Avatar
Default Re: Fuel Shut Off Valve
Because it's gravity feed, for safety, I would shut it off whenever the engine is shut down.
