Old 08-13-2021, 06:45 PM   #1
hardtimes
hardtimes's Avatar
Default Model A gas gauge parts ?
Among the parts that make up a model A gas guage, are a variety of ‘gaskets’.
Among the gaskets… is a brass band/ring/gasket.
QUESTION:
Without guessing, can anyone explain the function(s)/reason for existence of this metal ring(s), in gas gauge ?
Also, IF THIS IS A proper gas gauge part…. HOW many such brass rings are used in a gas gauge ?
Also, where is brass ring located in a properly rebuilt gas gauge ?
Old 08-13-2021, 07:34 PM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Model A gas gauge parts ?
The brass ring is a slip ring that enables tightening the outer nut without rotating the inner parts. In other words, the brass ring reduces friction.
Bob Bidonde
Old 08-13-2021, 07:51 PM   #3
mercman from oz
mercman from oz's Avatar
Gas Tank - Gas Gauge Installation Diagram.
Old 08-13-2021, 08:37 PM   #4
Tom Endy
Tom Endy's Avatar
My experience has been that you need more than one brass slip ring. Reason, I have had the assembly bottom out on the threads before it was tight on the gaskets and it leaked fuel. doesn't hurt to put two or three on.
Tom Endy
Old 08-13-2021, 09:12 PM   #5
Mister Moose
Mister Moose's Avatar
Tom Endy
Same experience here. I thought it might be that the cork was compressed a little, found that happened when I fixed a sunken cork float. Added a second brass ring and it sealed better.
Mister Moose is offline   Reply With Quote
Old 08-13-2021, 10:08 PM   #6
CarlG
CarlG's Avatar
Those little brass slip rings work wonders on radiator caps that leak, especially the monometer or quail type.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-14-2021, 01:40 AM   #7
hardtimes
hardtimes's Avatar
Tom Endy
Hey Tom,
GOOD info and helpful response !
I just got a “ rebuild “ kit from ford parts vendor….NO BRASS RING included !
I reviewed couple of my MODEL A shop manuals. No mention of brass ring… nor where it would be installed !
If a guy needs 2or3 to get a good no leak seal…where can I buy them.
BTW… the gauge that I just took out… has no brass ging(s) !!
No wonder some one put a mess of sealants in to TRY to seal gauge.
Old 08-14-2021, 01:47 AM   #8
hardtimes
hardtimes's Avatar
Hey oz,
Great schematic large enough for old eyes to see ! Thanks you guys for your help !!
Old 08-14-2021, 02:48 AM   #9
McMimmcs
McMimmcs's Avatar
Originally Posted by hardtimes View Post
Hey Tom,
Who was the vendor and did you contact them concerning the shortage ?
I
Old 08-14-2021, 07:11 AM   #10
1931 flamingo
1931 flamingo's Avatar
Use CORK gaskets, NOT the neoprene ones. Some say to assemble with a little Maple Syrup on the washers. FWIW
Paul in CT
Old 08-14-2021, 08:26 AM   #11
Bob Bidonde
I revised my tip to have 2 brass slip rings as Tom Endy suggests. As I recall, I did use 2 slip rings to get good clamp-up. Please discard the sketches above and use this one. Double click on the sketch to enlarge it.
Bob Bidonde
Old 08-14-2021, 08:39 AM   #12
Y-Blockhead
Y-Blockhead's Avatar
Hey Tom,
Bratton's has extra brass rings. https://www.brattons.com/brass-gas-g...ng-washer.html
Some vendors sell a gas gauge kit with a blue paper slip ring instead of the brass slip ring. I always use the brass one. It is usually the neoprene gasket set that has the paper slip ring.
Old 08-14-2021, 09:36 AM   #13
Badpuppy
Some early gauges used "paper" gaskets (1/32 fiber) and the 1/16 cork won't fit, the plate guide hole is too far inward. The newer faceplate tab also needs filing to fit the smaller hole. Steve Plucker has descriptions on his site.
Old 08-14-2021, 10:34 AM   #14
Tom Endy
Tom Endy's Avatar
Bratton's carries both the gaskets and the brass shims
13570 gas gauge gaskets $2.50 set
13571 gas gauge brass shims $1.15 each
Tom Endy
Old 08-15-2021, 01:34 AM   #15
hardtimes
hardtimes's Avatar
Y-Blockhead,
Thanks for your help and info… regarding the blue SLIP ring paper ring.
Never heard of that situation ?
AND, thanks for the referenced video !
Old 08-15-2021, 10:35 AM   #16
Badpuppy
I got a blue paper slip ring in the kit from Snyder's, I think it was. Too small at least for my repop and it broke. Brass ring from Mike's fit nicely.
Old 08-17-2021, 02:28 AM   #17
hardtimes
hardtimes's Avatar
FOLLOW UP INFO:
Well I used the schematic of gas gauge proper parts , and installation while finishing up a repair job of ‘29 gas gauge.
Excess sealant usage , was only part of problem !
Whoever put this gas gauge in this A….did not know sequence of parts install.
I got it all cleaned , and all parts/gaskets installed… including TWO brass rings.
Fingers crossed, it wont leak !!
Thanks all for your good help !!
