Old 03-20-2020, 09:10 AM   #21
Badpuppy
Default Re: 6v charging issue
Self exciting one-wire alternators have an internal resistor that helps it to start charging at low RPM. This small load can discharge the battery over several weeks, so it's necessary to disconnect the battery when stored for an extended time. I would also recommend a trickle charger on the battery - connected or not - when parked.
Badpuppy is offline   Reply With Quote
Old 03-20-2020, 09:12 AM   #22
30 Closed Cab PU
30 Closed Cab PU is offline   Reply With Quote
Old 03-20-2020, 01:30 PM   #23
cederholm
cederholm's Avatar
That is very useful info - thanks all!
~ Carl
cederholm is offline   Reply With Quote
Old 03-20-2020, 05:20 PM   #24
1931 flamingo
1931 flamingo's Avatar
After you get it repaired install a battery disconnect switch. This will eliminate the drain from the alt. That's what I did 9 years ago.
Paul in CT
Old 03-21-2020, 06:20 AM   #25
cederholm
cederholm's Avatar
100% agreed!
Paul in CT
Old 03-21-2020, 07:49 AM   #26
Patrick L.
Patrick L.'s Avatar
I like the disconnect where you can just reach down and get to it easily.
