01-17-2019, 01:15 PM | #1 |
30/31 Coupe Subrail Set-Up Measurements
Hey everyone,
I've been having a heck of a time finding mesurements/dimensions to get my subrails into my coupe. Can someone pull some measurements off their car? Some info I have found online is vague or plain ol' wrong. I'm looking for the measurement of the cross channels. I feel like I could get it figured if I had those measurements. Thanks you all for your time, Brent Fordbarn Subrail Question.jpg Edit: I'm pretty sure Bert's or Brookville is shooting me some #s. Last edited by Brent; 01-17-2019 at 01:29 PM. |
01-17-2019, 01:51 PM | #2 |
Re: 30/31 Coupe Subrail Set-Up Measurements
I have 31 coupe that is available to measure for you if you don't get any results from other sources.
01-18-2019, 08:03 AM | #3 |
Exactly what numbers are you looking for, ...and what are your plans (-restoration or rod) because there are many details that will need to be done for those to be corrrect. For example, the ends of the cross sills will need to be altered, and the area where the clinchnuts are installed will need to be dimpled and punched. There are a couple of modifications to the sills around the pillar lock and near the area where the frame crossmember will locate that also need to be done. It is probably more than anyone could ever type here. I don't really have a good answer for you. Sorry.
03-28-2019, 08:27 AM | #4 |
