Old 01-06-2022, 09:33 PM   #1
Brent
Brent's Avatar
Default 4 Square Holes in Model A Coupe Inner Door Panel - what for?
A gentleman just asked me what the 4 square holes and the corresponding center hole are for in this Model A Coupe door inner panel.
I don't know, so I came to you all. Is it for adjustment?
Brent is offline   Reply With Quote
Old 01-06-2022, 10:09 PM   #2
burner31
burner31's Avatar
Default Re: 4 Square Holes in Model A Coupe Inner Door Panel - what for?
What year?
Keith
Shawnee OK
'31 SW 160-B
Old 01-06-2022, 10:28 PM   #3
Brent
Brent's Avatar
1930 Coupe
Old 01-07-2022, 09:24 AM   #4
Brent
Brent's Avatar
Anyone?
Old 01-07-2022, 09:59 AM   #5
KenBolton
Isn’t it to receive the window regulator?
KenBolton is offline   Reply With Quote
Old 01-07-2022, 10:06 AM   #6
Brent
Brent's Avatar
The regulators mounts in the three holes diagonal from the area I am referencing.
Old 01-07-2022, 11:30 AM   #7
Bob from Northport
Bob from Northport's Avatar
It holds the window track assembly that brings the glass up and down.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-07-2022, 11:57 AM   #8
Brent
Brent's Avatar
So, both sets of holes are for different regulators? For coupes?
Old 01-07-2022, 12:30 PM   #9
Bob from Northport
The upper one is for the crank handle that has an arm on it. It attaches to a long wide bar that the glass sits in It in turn attaches to the crank arm. I'll send photos this afternoon.
I have a coupe in my shop with the doors completely opened up
Bob from Northport
Northport, Michigan
Old 01-07-2022, 01:11 PM   #10
Brent
Brent's Avatar
Thanks.
All my doors (currently 4 of them in the shop) only had the 3-hole window crank/regulator assembly mounted in the holes diagonal from the circled area. My build has been so slow I'd never thought about the other square holes until I was asked.
Old 01-07-2022, 06:16 PM   #11
Bob from Northport
I misspoke. The four holes are NOT used at all on a coupe. They are the same as a four door car. The four holes are where to door opening handle mount. Coupes are different.
This photo of the drivers on a sport coupe might help.
Ford may have used the same panels in different car doors
Bob from Northport
Northport, Michigan
Old 01-07-2022, 06:36 PM   #12
Brent
Brent's Avatar
The mystery continues! Thanks.
Old 01-08-2022, 09:51 AM   #13
Aretino
Aretino's Avatar
Mounting holes for optional power window regulator.
Aretino is offline   Reply With Quote
Old 01-08-2022, 09:58 AM   #14
rich b
rich b's Avatar
Ford put that feature there so we can easily pick out coupe doors at swap meets, auctions, dusty barns, and in past times junkyard door piles.
