02-06-2024, 10:57 PM | #1 |
Flywheel 1934 1936 ,
Can someone spread some light please , when did the flat head v8 go from the dished , (recess )flywheel to the flat one ? Will the interchange ? Thanks again
02-07-2024, 03:59 PM | #2 |
Re: Flywheel 1934 1936 ,
I believe the flat 10" flywheel came in about 41. The dished are all 9" I think. The crank flange is the same model T thru 53, but the 8ba's use a different flywheel due to starter location. 8ba flywheels have thru holes for the pressure plate, where as earlier v8's have blind holes there.
02-07-2024, 04:05 PM | #3 |
