10-30-2022, 05:54 PM | #1 |
Question about stock 34 fuel pump and electric pump
So both my cars have an electric pump on it, used to prime when starting. So my question is if you left the electric pump on, can it push through the stock pump and end up giving the carb too much fuel/pressure?
10-30-2022, 06:12 PM | #2 |
Re: Question about stock 34 fuel pump and electric pump
Been running mine like that for years. It’ll push through the mechanical pump and it won’t increase the pressure.
10-30-2022, 06:15 PM | #3 |
[QUOTE=Ken/Alabama;2177735]Been running mine like that for years. Itll push through the mechanical pump and it wont increase the pressure.
Say what???
10-30-2022, 07:20 PM | #4 |
So I crawled under the car and interesting set up its the electric fuel pump, and then behind it is a fuel gauge regulator, it was set at five psi, I turned it down to four, but then disconnected it completely, and the car starts up instantly no issues. So maybe I should just set it at 2 1/2 pounds and let it go? Any suggestions appreciated see photo. Or do a on/off switch at the dash.
10-30-2022, 09:00 PM | #5 |
The regulator is between the tank and fuel pump ???? That's what it looks like in he photo. That's weird.
10-30-2022, 09:10 PM | #6 |
10-30-2022, 09:34 PM | #7 |
Regulator is between the electric pump and The mechanical pump
10-30-2022, 10:52 PM | #8 |
a good stock fuel pump is ok for most applications, i use an electric pump mounted near the fuel tank wired to a spring loaded momentary switch, so it will not be left on, for priming the carburetor if the car sits for long periods
10-31-2022, 06:35 AM | #9 |
I bought my ’34 roadster in 1995. It came with an original style fuel pump and a very heavy piston type electric fuel pump mounted behind the driver side hood panel close to the frame with an immediate switch located on the lip at the bottom of the dashboard. It also had a variable style pressure regulator mounted on the intake manifold close to the carburetor. I assume that the previous owner did not want to separate the fuel and fuel gauge tubes. The car had an 8-volt battery, and the electric pump went south soon after I bought the car. I replaced this with a 6-volt battery and a new light weight electric pump. I also replaced the immediate toggle switch with a tiny nearly invisible black colored switch.
Some years later the regulator failed, and I never replaced it. The car now has a fuel pump rebuilt by CharlieNY and I don’t feel that it needs a regulator as I never smell any gas and the is running like new. |
10-31-2022, 07:52 AM | #10 |
I don't believe the numbers on the regulator correspond with the output pressure. When you get your vacuum gauge it most likely can also do fuel pump pressure. Don't continue to make adjustments until you get the Carb idle mixture adjusted.
10-31-2022, 08:39 AM | #11 |
After I had a few years experience with these cars and had some idea of what actually is going on, I set my car up correctly, scrapped the electric fuel pump, and have never regretted it.
10-31-2022, 09:15 AM | #12 |
I don't need the electric fuel pump on my '34 unless it hasn't been driven for a month or so. My '37 doesn't have one and when it hasn't been driven for a while I need to use starter fluid to start it. This is a pain when I'm alone.
10-31-2022, 09:35 AM | #13 |
Bingo!
11-01-2022, 11:48 AM | #14 |
Automobiles, like any other motorized vehicle, do not like to set too long. The military got me used to the 14 day MOC or maintenance operational check. Much longer than that and the vehicle should be prepped for storage. With the funky modern fuels we have and the price of batteries, I would strongly recommend running then every two weeks. In the winter, they should be drained of fuel and the battery removed for periodic charging. Also make sure the coolant is up to low temperatures or drain it.
