07-27-2013, 08:53 AM | #1 |
1931
I just bought a 1931 ford. It started backing firing. I checked points and rotor gap ok. Not sure if it is timmed correct of may have too much play in distributer shaft. used you tube and Les Andrews book. I did find the exhaust gasket leaking. the compression is 68 to 70 psig in all cyclinders. can any one help me before i just easter egg. Motor is clean inside like new . I replaced gas. This problem started when i was leaving a show it was hot outside.
07-27-2013, 08:59 AM | #2 |
Re: 1931
Condensor going bad maybe. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
07-27-2013, 08:59 AM | #3 |
Re: 1931
check timing carefully . check for good fuel flow . check for intake leaks . good luck .. steve
*** as above replace cond.
V4f |
07-27-2013, 09:42 AM | #4 |
Re: 1931
Re set the points @ .020. The rubbing block wears a bit when they're new. They may be closing
07-27-2013, 09:51 AM | #5 |
Re: 1931
The condenser can cause it ---buy an A&L burnout proof one
The exhaust leak can also cause exhaust explosions (sound like "backfire"but out muffler) ---at times there is a vacuum in the exhaust, that draws air into through the leak, unburned fuel ignites making a sound like backfire Too lean can cause backfire out carb-- Does it happen mopre when accelerating, at cruise, or coasting? |
07-27-2013, 10:12 AM | #6 | |
Re: 1931
Here is an excellent lesson on timing, www.abarnyard.com/workshop/timing.htm
07-27-2013, 10:30 AM | #7 |
Re: 1931
Yep, to all the above. Also, try loosening the fuel cap. Was there a previous problem or did this just start ? Have you asked the previous owner ?
