Old 03-17-2024, 07:16 PM   #1
pt5win30
Default Vulcan 1 cylinder head
Hello! Looking for some help picked this head up can’t find anything after searching. What’s the story on it? When was it made? What compression ratio? No hole for a stock distributor alignment pin. Could a stock distributor be made to fit? Any info would be greatly appreciated
pt5win30 is offline   Reply With Quote
Old 03-17-2024, 08:03 PM   #2
Flathead
Flathead's Avatar
Default Re: Vulcan 1 cylinder head
Looks like it was cast to be able to add the distributor pin hole, just mark it and drill it.
Flathead is offline   Reply With Quote
Old 03-17-2024, 08:42 PM   #3
nkaminar
nkaminar's Avatar
You may have a hard time finding a gasket to fit. The stock distributor may not work because of the plug locations. Otherwise, I like it.
Old 03-17-2024, 09:30 PM   #4
PC/SR
Combustion chamber looks like a repo Winfield I have. Hard to tell the CR without ccing the chamber but it looks bigger than the 7-1 Winfield. Just a WA guess, somewhere around 6-1. Don't really need the distributor pin hole. Time it the regular way aligning the contact points then mark the pin location and drill.
PC/SR is offline   Reply With Quote
Old 03-17-2024, 09:30 PM   #5
jeepguy1948
The only way you will know what the cr is will be to “CC” the chambers. Anything else is nothing better than a guess
jeepguy1948 is online now   Reply With Quote
Old 03-18-2024, 11:01 AM   #6
Jim Brierley
It was made in the 70's in the San Bernardino area. There was a Model A guy that owned a parts store there and he produced a few performance parts. I think his last name was James???
Most any Model A gasket will fit, place it on the head and see that the gasket doesn't hang out into the chamber.
Old 03-18-2024, 01:07 PM   #7
alexiskai
alexiskai's Avatar
Definitely looks "inspired by" the Winfield heads, down to the plug location and (eyeballing it) being threaded for 14mm plugs.
Old 03-19-2024, 10:35 AM   #8
katy
katy's Avatar
Ditto
Is that aluminum?
