02-16-2021, 07:31 PM | #1 |
8RT truck oil pan question
On a 48-52 8RT truck oil pan with the large clean out can I access the oil pump pick up tube without dropping the pan ?
Traced my knocking noise to the oil pan and suspect an interference problem. Pulled plug wires one cylinder one at time no difference in noise. Oil pressure is fine. All rod/main clearances were good when assembled. Any suggestions ? |
02-16-2021, 07:45 PM | #2 |
Re: 8RT truck oil pan question
OOps, I just read you used the stethescope technique. Glade you found it. Will using a metal rod touching the oil pan and holding it to your ear work?
Please let us know "the rest of the story". Good luck. Last edited by 19Fordy; 02-16-2021 at 07:50 PM. |
02-16-2021, 07:52 PM | #3 |
Stethoscope, should have checked that sooner. Bought it at Harbor freight, cheap, and works well.
02-16-2021, 07:58 PM | #4 |
Mechanic stethoscope at harbor freight 4.99 ,works better than screw driver
02-16-2021, 09:02 PM | #5 |
You can not access the tube through the cleanout, only the screen. You could try draining the oil, remove the cleanout and have someone crank the engine while you feel the screen. If the crank is hitting the tube, you should be able to feel it.
02-16-2021, 09:33 PM | #6 |
02-16-2021, 11:46 PM | #7 |
02-17-2021, 02:10 PM | #8 |
Be careful bending that tube... I have had some problems with those two attachment bolts stripping over the years while installing tube to pump.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Thread Tools | |
Display Modes | |
