02-02-2021, 04:34 PM | #1 |
Engine mount
Hi, does anyone make the rubber front engine mounts for the y blocks?
02-02-2021, 04:39 PM | #2 |
Re: Engine mount
The front motor mounts are 1954 - 1958 (two studs on top & bottom) and
1959 - 1962 (two studs on top , 1 stud on bottom), T Bird are very different.... I have all of them Brand New, You are welcome to call me... Craig --- 516 - 485 - 1935, Long Island, New York.... Some Snow we got these last 36 hours, eh ??? |
02-02-2021, 06:17 PM | #3 |
Re: Engine mount
i think hes talking about the steady rest.maybe.
02-02-2021, 07:01 PM | #4 |
Re: Engine mount
If you have new or very good side mounts, the steady rest is not needed.
02-02-2021, 08:27 PM | #5 |
Re: Engine mount
Did you check with Carpenter. Remember, the front mount on a sedan is called a steady rest, not an engine mount.
02-02-2021, 08:39 PM | #6 |
Re: Engine mount
02-03-2021, 01:09 PM | #7 |
Re: Engine mount
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-03-2021, 01:12 PM | #8 |
Re: Engine mount
a 56 is hard enough to work around that steadyrest just adds to it.toss it.
02-03-2021, 05:20 PM | #9 |
Re: Engine mount
Don't can it as someone will be looking for one.
02-03-2021, 06:15 PM | #10 |
Re: Engine mount
Thanks for the help!
02-03-2021, 07:44 PM | #11 |
Re: Engine mount
Thread Tools | |
Display Modes | |
