Old 01-26-2021, 04:27 PM   #1
fast fredy
Default door glass rollers
Hi guys , on my 55 wagon whats the secret or trick to get new rollers installed in the channel on the bottom of the glass and so the clip is not in the way of sliding it onto the stud of the winder assembly , just cant get my head around it thanks in advance Fred
fast fredy is offline   Reply With Quote
Old 01-26-2021, 05:15 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: door glass rollers
From the '53 shop manual, '55 will be the same:
Install the rollers in the channel.
Raise the arm and pivot assembly into the door. Before locating the 3 retaining screw holes start the upper roller into the roller guide. Install the 3 retaining screws but do not tighten at this time.
Connect the regulator link to the arm and plate assembly and install the retaining pin.
Adjust the arm and plate assembly to reestablish proper glass alignment.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 01-26-2021, 09:43 PM   #3
fast fredy
thanks dobie
Old 02-02-2021, 04:08 PM   #4
Gene F
Gene F's Avatar
The hard part is getting the rollers and hardware. Where did you find them?
Gene F is offline   Reply With Quote
Old 02-03-2021, 08:18 PM   #5
fast fredy
I think it was Larrys T bird
Old 02-03-2021, 08:42 PM   #6
paul2748
paul2748's Avatar
I know the Tbird vendors have them, assume the other Ford parts people have them
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-06-2021, 03:07 PM   #7
Gene F
Gene F's Avatar
Thanks
Old 02-10-2021, 08:41 AM   #8
bobss396
bobss396's Avatar
Be careful with rollers, some parts places use one for everything. If the car came with the red ones, get the red ones. The later blue ones will need modification to fit. Some older glass shops still may have them.
bobss396 is offline   Reply With Quote
