04-15-2014, 09:39 AM | #1 |
stainless trim clips '36 grille
I am putting the stainless on a '36 grille not previously drilled for the trim. I think that rather than use the original spring type clips, I would like to secure the trim with those universal trim clips that have the 10-32 stud and rectangular flat metal top that can be trimmed down to fit inside the s/s trim. I can find batches of them on the 'bay, but wondering if anyone in Fordbarn world has a good source for them. Or, other suggestions for securing the trim to the grille would be appreciated. Thanks.
04-15-2014, 09:53 AM | #2 |
Re: stainless trim clips '36 grille
Try looking at part number 40-8200-HK from Bob Drake.
1934 grill trim hardware kit. I used them on my 36 for both the grill trim and the spare tire trim. Worked well. |
04-15-2014, 12:27 PM | #3 |
Thanks, 41. After looking at them, could it be that they are just small carriage bolts?
04-15-2014, 02:29 PM | #4 |
The problem with those nut plates is in certain areas you can't get a wrench or socket on the nut.I used the repo clips and they worked out fine.I got my clips from The Early Ford Store in CA
04-15-2014, 02:50 PM | #5 |
Just did a search of 10-32 carriage bolt dimensions. The square shoulder is .185 to .199 and measuring the inside slot of the s/s it looks like about .200. I think 41 may have given me a great idea to use the carriage bolts.
D.L., that's why we have drills to put holes where Henry should have. |
04-15-2014, 05:16 PM | #6 |
https://fordbarn.com/forum/showthread...light=36+grill |
