Old 11-03-2020, 05:53 PM   #1
Hairycanary
Hairycanary's Avatar
Default Ford Banjo Ring Gear Carrier ID
I am assembling a 1940 banjo from parts I have collected. Just found this ring gear carrier, but it looks different than others I have seen.
Can someone ID what year it is from?
Thanks,
Dave
Hairycanary is offline   Reply With Quote
Old 11-04-2020, 03:17 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Ford Banjo Ring Gear Carrier ID
With the size of the photo, it's hard to tell. They made the same basic assembly from 1932 through 1948 but there may be variations in appearance. The main thing is that they have the same dimensions for the bearing, bolt pattern, and overall length from the ring gear attach face to the lip on the bearing journal where the bearing seats.
The ones I have, have number casting marks like 18 in one spot and 4206 on another in between the special bolt heads. There is also a foundry mark on there too. The part numbers for the two halves were 18-4205 and 18-4206. If it has a B then it would likely be the model A/B type part with the B prefixes if made after the start of model B production.
Old 11-04-2020, 03:22 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Looks like the typical 1940 to 1948 carrier assembly. The earlier carrier hub diameter the long round area where the bearing is located at the end is a smaller diameter outside its noticeable just by looking at the two assembly's. Then there's the 1932 carrier which is completely different.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 11-04-2020, 03:28 PM   #4
Hairycanary
Thanks Rotorwrench! Very helpful. Good to know they all have the same bolt pattern and dimensions. I will check the casting marks and see what it has.
Old 11-04-2020, 03:29 PM   #5
Hairycanary
Thanks Ronnie for the additional info. Sounds like I can run it in my banjo.
