08-18-2012, 11:25 PM | #21 | |
Re: How fast can an 80 year old A engine go?
Carbs are Winfields (one updraft and one down draft) and as I remember it looks like it will fit an A block but no one has tried it yet. He was going to try it and see if it might fit. The stock exhaust manifold MIGHT get in the way. The history of it is unknown. It looks like a super charger from this angle but the Alum part is a 1/2 circle machined manifold. The circular part is the Aluminum manifold. I will look closer the next time I go by the store to see if it matches up with an A or B block. The fuel line should be pointing down as it looks to be made for a Model B fuel pump. Guess I got it wrong when I took the picture. Last edited by Benson; 08-19-2012 at 09:46 AM. Reason: additional info |
08-18-2012, 11:26 PM | #22 |
E.J.Kowalski holds that Record at 114.266 set at Bonneville in 2011. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
08-19-2012, 12:24 AM | #23 | |
Kent Fuller has a streamliner, vintage flathead V/8 he says will be at Bonneville next year.
Steve - Santa Rosa |
08-19-2012, 01:09 AM | #24 |
My complaint is that is not in any way a "model A engine". A model A engine BLOCK yeah, but thats about all.
08-19-2012, 07:45 AM | #25 | |
Thanks for replying. I had to think about Steve Becker for a minute. Then It popped into my head- BERT'S MODEL "A". I always like dealing with Bert's. I think they are friends with Paul Talley. Paul sold me a 38 Chevy when I was in High School. I have not seen Paul for about 10 years. Paul and his brothers were always working on cars when I was a small child. His one brother bought a new 58 Edsel convertible with a continental kit. It was a pretty car. I think Paul lives in Cheyenne, Wyoming at the present time. Al Satreelee is a friend that is building a 29 Model "A" roadster. He stopped at Bert's for some parts this spring. Al and Paul are about the same age. Al said Bert's was neat place to visit and enjoyed his shopping spree. Maybe you could take some more pictures when you visit Phil and Steve.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
08-19-2012, 09:16 AM | #26 |
08-19-2012, 09:55 AM | #27 | |
Peter, My source who was at Bonneville said at coffee that they turned 6600 through the trap. My guess is that the crank most likely has 5 mains and re-enforced main caps, full oil pressure and such. |
08-19-2012, 11:06 AM | #28 |
Joel Young from Phoenix ran 225 this year in his flathead Model T streamliner. Yes, flathead Model T!!! Aardema's engine started life as a Model A but his block has been very extensively modified. Joel's T has been 4-ported and has a 5-main crank with a bolted on girdle, a comparatively stock block. Greg Martinez holds the record in V4F/lakester, not sure if it was on gas or alky?
08-19-2012, 11:21 AM | #29 | |
Bonneville is a great event and so different than other car events.
08-19-2012, 10:45 PM | #30 | |
Bonneville Fast A’s Jim Brierly gave you the low down on the 5 main girdle used by many of the guys running the lakes and salt. What he didn’t say is that he and his partner set the record in their class last year I believe, by going 163.00 mph. with 3 mains, babbit bearings and I believe a stock crank. The gentleman in an earlier reply to this post had commented that these engines were not really stock. He is correct, but Jim and others like him have extended mostly stock to the current level, exceeding by a long ways what we used to think was unattainable. The improvements these people are doing have found their way into the rebuilds we use in our A’s today. Such things as improved oiling systems, filters, insert bearings; high compression heads and etc. are common place today. All of these ideas that did not exist when our engines were originally made are now available to add life and durability to our power plants. Yes some of the guys have stretched the word stock block, but the vintage class is just for this and enjoyed by many who love the challenge, flathead V/8’s both Ford and Cadillac , Model A’s, Buick 8’s and others. The five main bearing approach has been proven to superior to three mains of the original Model A. The new stock appearing block and crank that Terry Burtz is developing incorporates most of what is mentioned above, including 5 mains and counter balanced crank. We will be able to enjoy greatly increased durability and reliability as a result of the efforts of the racers and suppliers such as Terry Burtz. The head gasket problem we all experience is exaggerated when racing. An innovated approach that one of the record flathead 4 cylinder holders has employed is additional head bolt/studs. He has welded bosses to his blocks and heads that help seal the head gaskets. Ford didn’t get it right with the Model A (14 studs), tried with the new flathead V/8 (21 studs) and had to go to 24 studs finally to solve the problem that we all face. These types of experimentation, leads to possible improvements for us all. While I have your attention, I would like to put in a plug for the MAFFI Museum. I am a board member and would like to encourage you to contact me about an easy way to raise funds for your museum. I have a no cost simple way for your club to be involved, it is so simple you will wonder why didn’t think of it yourself. Also I would like to remind you of the Museum Dedication Sept.15th Model A Day; I will be there and would like to meet you. For those of you that will be attending the SEMA Show, I will be there as the Representative for MAFFI. John LaVoy of Model A Times and me along with two others will be in the Ford Motor Co. display with John’s Model A. With the A on display we hope gather some interest in our Model A Ford Museum from some of the manufacturers at the show. If you are in attendance please stop by and say hello.
08-20-2012, 08:39 AM | #31 |
I'm not being sarcastic just curious but aren't we sort of starting to describe the old Offenhauser engines?
08-20-2012, 09:21 AM | #32 |
Clearly this is the most evolved Model A engine on the planet, but remember...DOHC, girdle-based 5 mains, specially machined everything, lots of attention to keeping all the smoke inside...all of that was happening throughout the '20's and '30's with T's and A's in sprintcars. This thing is part of a looong tradition, the proud American tradition of turning scrap Ford parts into insanely overachieving rockets. And remember...a T block went 200 not very long ago!
