Old 07-08-2020, 01:48 PM   #1
rer_239
rer_239's Avatar
Default wiring harness
no lights, no horn. question the business end of the harness is a round disc with 9 terminals. those terminals are in 3 groups of three looking at the back side it looks like each set is tied together. so if i put one wire from an ohm meter on one wire in the back should i get continuity when i put the other wire from the meter on each of the nine terminals on the front?
rer_239 is offline   Reply With Quote
Old 07-08-2020, 02:49 PM   #2
Werner
Werner's Avatar
Default Re: wiring harness
No. The current is directed to the individual contacts via the three point-shaped brass contact plate that you can turn from the steering wheel.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-08-2020, 03:07 PM   #3
rer_239
rer_239's Avatar
Ok are you saying I should not get continuity on all nine front terminal s? Thanks for the response.
Old 07-08-2020, 03:55 PM   #4
Bob C
The three terminals for the tail light are hooked together and the three terminals for the battery are hooked together. The three for the headlights are not.
Old 07-09-2020, 11:37 AM   #5
Badpuppy
No lights or horn means the two yellow wires are open at the cutout terminal (running). If not running, could be open at the firewall or ammeter (or fuse).
Old 07-09-2020, 03:11 PM   #6
Werner
Werner's Avatar
Bob C, I call this contribution as a perfect help!
Werner
Citroen 11 CV, 1947
Old 07-12-2020, 04:27 AM   #7
rer_239
rer_239's Avatar
Like always good helpful info.
Thanks
