12-15-2010, 08:24 PM | #1 |
Logged in????
The following is a copy of the screen: You do not have permission to perform this action. Please refresh the page and login before trying again. Okay Message: <P>"The Bed has wood planks for the floor, I assume not original as there seems to be a metal floor listed for it?"</P> <P> </P> <P>You are correct in that assumption. There were 1x oak planks covered by ribbed sheet metal with approx. two dozen carriage bolts through the metal and the gap between the wood planks. A flat washer was used to bridge the gap where the bolts went between the planks. Also the planks had a square cut out for the rear spring perch and U-bolts.<BR></P> Options Quote message in reply? Posting Quick Reply - Please Wait « Previous Thread | Next Thread » Thread Tools Show Printable Version Email this Page Subscribe to this Thread Display Modes Linear Mode Switch to Hybrid Mode Switch to Threaded Mode Search this Thread Advanced Search Rate This Thread Excellent Good Average Bad Terrible Posting Rules You may post new threads You may post replies You may post attachments You may edit your posts |
