Old 10-21-2020, 05:35 PM   #1
fredski53
fredski53's Avatar
Default Oil Breather tube 20 inch flex tube
Greetings and salutations; what are the people's thoughts of adding a oil breather flex tube to your engine? Wife and I went on a 75 mile ride this weekend and all she did was complain about the smell of oil flumes in the car! Do I add a breather tube or don't let her ride anymore?
fredski53 is offline   Reply With Quote
Old 10-21-2020, 05:40 PM   #2
Bob-A
Bob-A's Avatar
Thumbs up Re: Oil Breather tube 20 inch flex tube
Breather tube....it'll be cheaper in the long run.
Bob-A
Bob-A is offline   Reply With Quote
Old 10-21-2020, 05:45 PM   #3
WHN
Default Re: Oil Breather tube 20 inch flex tube
Breather tube really helps. Keeps firewall clean, no funny smells.
Enjoy.
WHN is online now   Reply With Quote
Old 10-21-2020, 05:48 PM   #4
Big hammer
How much blow by do you have? Engine overhauls aren't cheap, neither are divorces !
get a bigger hammer tap done
Old 10-21-2020, 06:20 PM   #5
rfitzpatrick
Like mine -- the only problem I had was when changed oil, didn't put the funnel down far enough, before discovered oil I was adding was going to the floor thru the breather line.
rfitzpatrick is offline   Reply With Quote
Old 10-21-2020, 06:50 PM   #6
Conaway2
Conaway2's Avatar
I’ve been using an old Fumaze breather cap/tube for 50 years - no more complaints from passengers about the oil fumes.
Conaway2 is offline   Reply With Quote
Old 10-21-2020, 07:47 PM   #7
RUNNERBUN
RUNNERBUN's Avatar
Put the breather tube in, remember happy wife = happy life.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 10-21-2020, 07:57 PM   #8
eagle
eagle's Avatar
Maybe SHE needs the "breather tube". Seriously though, I have one on my A and I don't notice any oil fume smell in the car.
Old 10-21-2020, 09:34 PM   #9
Alaska Mike
Several friends that have did the "divorce thing" all agree, "Cheaper to Keep'er"
Alaska Mike is offline   Reply With Quote
Old 10-21-2020, 09:53 PM   #10
PalAl
PalAl's Avatar
Installed one about 4 years ago, really helps with fumes and oil mist. I like to keep my engine compartment tidy. This picture was taken about a year after the install. A long neck funnel is needed for oil changes.
PalAl is offline   Reply With Quote
Old 10-21-2020, 09:58 PM   #11
Synchro909
Synchro909's Avatar
You'll be able to stop the fumes coming in by opening the windscreen a little and closing the other windows, assuming you are in a closed car. Doing that gives a slight positive air pressure in the car and stops the fumes entering. I do that to stop the HOT air coming in around the pedals. (On a RHD car, the exhaust pipe is between the clutch and brake pedals)
Old 10-21-2020, 11:03 PM   #12
bdtutton
I have very little blow by from my engine so there was hardly any smell, but my wife could smell it. The breather tube helped.
bdtutton is offline   Reply With Quote
Old 10-22-2020, 03:41 AM   #13
old31
Geee, it would be cheaper to leave the wife at home. Those breather tubes are $35.00.
Actually I installed one and they work great.
old31 is offline   Reply With Quote
Old 10-24-2020, 07:29 PM   #14
fredski53
fredski53's Avatar
Thanks for all the positive responses! The engine is a fresh rebuild, but the wife has a sensitive nose! I'll tell to let Santa get one for Christmas
Old 10-24-2020, 09:10 PM   #15
PalAl
PalAl's Avatar
Also tell Santa to bring a long funnel to get the new oil past the tube
Old 10-24-2020, 09:57 PM   #16
160B
160B's Avatar
If you keep your eye out you may find a FUMAZE at a swap meet. There are originals and reproductions.
The originals have are marked FUMAZE PAT. PEND P.O.B. MFG.CO CINN. O. and the tube is seamed.
The reproductions are marked FUMAZE PATENTED IN USA, and the tube is not seamed, it is solid pipe.
see below photos
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 10-25-2020, 12:01 AM   #17
Ruth
see below photos
Do you need to cut a hole in the engine pan when using the Fumaze? Or remove the engine pan?? If so I would rather use the flex tube.
Ruth
Old 10-25-2020, 12:24 AM   #18
Cory Moffat
Cory Moffat's Avatar
A total rebuild is funner and a whole lot cheaper. Also can be justified as it's for her.
Because Dear I love you.
Cory Moffat is offline   Reply With Quote
Old 10-25-2020, 01:42 AM   #19
CarlG
CarlG's Avatar
No alterations to your engine pan. In fact, the engine pan adds to it's effectiveness. I've been using one for 10 years now. works great!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-25-2020, 02:05 AM   #20
McMimmcs
McMimmcs's Avatar
kick her ass to the curb. Once you fix the fumes problem she’ll find something else to complain about.
