Old 04-06-2020, 03:20 PM   #1
Farley's34
Default 1932 Throttle pedal to bellcrank length
What is the correct rod length from the pedal to the bellcrank on a 32 V/8?
Farley's34 is offline   Reply With Quote
Old 04-06-2020, 04:25 PM   #2
earlyride
earlyride's Avatar
Default Re: 1932 Throttle pedal to bellcrank length
I measured mine at 9 3/4 inches from center of the pivot balls at each end
earlyride is offline   Reply With Quote
Old 04-06-2020, 04:59 PM   #3
35fordtn
35fordtn's Avatar
They measure around 9.7" not installed and 10" installed (measured at the ball opening)
Like stated in the post above
35fordtn is offline   Reply With Quote
Old 04-07-2020, 07:42 AM   #4
Farley's34
Got it. Thank You!
Old 04-08-2020, 01:20 PM   #5
Strick
Strick's Avatar
is this the rod that runs from underneath the dash tunnel down to the pedal? if so, looking for one...
1940 Mercury
Looking for DENVER heads - 81AS - 99AS - 19AS
Strick is offline   Reply With Quote
