Old 09-13-2019, 08:10 PM   #21
Greg58
Greg58's Avatar
Default Re: Overdrive lockout cable on a '51 Ford
The cable clamp on mine is on the top mounting bolt of the solenoid.
Greg
Greg58 is offline   Reply With Quote
Old 09-13-2019, 08:11 PM   #22
tubman
tubman's Avatar
Well, it looks like I have (or can make) everything I need except except the way the cable attaches to the overdrive lockout lever on the transmission. Emmit, if you are still with your car, could you get a picture of that? The sleeve shown looks like a part of it, but I don't have any idea what goes through the lever itself.
Any help will be appreciated.
Old 09-13-2019, 08:13 PM   #23
tubman
tubman's Avatar
Greg, That makes a lot of sense, Any chance of getting a close up of that area?
Old 09-13-2019, 08:14 PM   #24
Greg58
Greg58's Avatar
Mine is a bolt with a cross drilled hole.
Greg
Old 09-13-2019, 08:27 PM   #25
Emmit51
Emmit51's Avatar
Here is what i could get a photo of. As Greg said, looks like the cable is attached near the top of the solenoid at left in the photo, and the central wire can be seen attached to the lock out level toward the right. Sorry, hard to get a photo above the solenoid when it is in the car
File Type: jpeg 614AF7B1-9B96-4DD6-8151-AC040BAEE589.jpeg (105.9 KB, 21 views)
Emmit51 is offline   Reply With Quote
Old 09-13-2019, 08:31 PM   #26
Greg58
Greg58's Avatar
That was my problem, I couldn't get under the car. FYI I had to use a ball peen hammer to make clearance for the lever.
Greg
Old 09-13-2019, 08:38 PM   #27
Greg58
Greg58's Avatar
Tubman are you installing a 51 trans? 49 and 50 use the narrow mount and is about 1-1/2" back towards the tail. I have a 51 trans in mine and had to weld to the 51 mount to use it in the 50.
Greg
Old 09-13-2019, 08:50 PM   #28
Greg58
Greg58's Avatar
I would take measurements from the center of the tunnel to the center of the output shaft and output shaft to the frame just to be safe. Once I figured out I had a 51 od trans and needed to make a mount I had to put my stock trans back in to get the measurements.
Greg
Old 09-14-2019, 07:04 AM   #29
tubman
tubman's Avatar
I have two '51 transmissions and one '50 transmission, so I am well aware of the differences. It's pretty obvious when you can see them side by side.
Old 09-14-2019, 01:48 PM   #30
Greg58
Greg58's Avatar
Good deal, I just didn’t want you to have to go through what I did, I thought I could simply turn the mount around and it would fit, I was wrong. I had to put the stock 3 speed back in to get the ride height to make the mount for the 51 trans with a 50 cross member.
Greg
