Old 09-08-2018, 11:42 AM   #1
Roadster62
Roadster62's Avatar
Default 38-39 Truck Door Lock removal
My 1939 Pickup project is slowly moving along. How do I remove the door lock? There is a hole in the door jamb side, can't tell if there is a screw or nut in there. Thanks! Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 09-08-2018, 09:16 PM   #2
nelsb01
nelsb01's Avatar
Default Re: 38-39 Truck Door Lock removal
Do a little clean up and see. Over the years who knows what was done -- my 1936 pickup had an alan head threaded one. Not what was in there originally.
It should be a small screw that will either snap off or the slot will be shaved off when you attempt to remove it. Soak it with some of the best penetrating lube you have, and be patient. You dont want to drill it out.
nelsb01 is offline   Reply With Quote
Old 09-09-2018, 01:48 AM   #3
deuce lover
deuce lover's Avatar
The originals have a slotted head set screw.Very often they are broken which was the case in a 35 sedan I had .Difficult to get to and get out I ended up drilling it which wasn't easy.
deuce lover is offline   Reply With Quote
Old 09-09-2018, 08:06 AM   #4
marko39
just did this on my 39 tudor. it had a screw which looked like it was never touched. i proceeded to snap off half of it making it a real pain to drill out. finally got it out before ruining the tube that holds the screw. had to tap tube for a larger size and got it back together. Mark
marko39 is offline   Reply With Quote
Old 09-09-2018, 11:45 AM   #5
Roadster62
Roadster62's Avatar
Thanks! Mine is a slotted head, soaked it with Kroil, will give it a test later today.
Bob
Old 09-09-2018, 01:01 PM   #6
Roadster62
Roadster62's Avatar
Thanks again! Got the set screw out. Bob
Old 09-09-2018, 11:19 PM   #7
Tinker
Tinker's Avatar
Nice work. Never hurts to hit it with some kroil first.
