04-20-2020, 06:53 PM | #1 |
cylinder bore
what is the factory bore, our car has 3.945 i'm wanting to get started on the rebuild and machining
04-20-2020, 06:59 PM | #2 |
Re: cylinder bore
3.875"
04-20-2020, 07:52 PM | #3 |
Re: cylinder bore
so I have the original pistons then, can i go up in rings and keep my pistons?
04-20-2020, 08:22 PM | #4 |
Re: cylinder bore
Did you measure the bore with an inside mice? did you measure the outside of piston just below the bottom ring?
If the bore is 3.945" and the piston is stock 3.875" then the clearance is .070" On a new rebuilt engine the clearance between the piston and cylinder is .0035" to .005" |
04-21-2020, 04:29 AM | #5 | |
Re: cylinder bore
Not sure how I know but you will have about 50psi and some blow by and some oil burning. A few links from Google. https://www.hotrodders.com/forum/ove...glepost11.html https://forums.aaca.org/topic/324870...omment-1863525 https://www.youtube.com/watch?v=Wadmzv1Vs0Q Those NZ'ers know a thing or two. https://www.youtube.com/watch?v=hXc3iXGucFs |
04-20-2020, 08:29 PM | #6 |
Re: cylinder bore
04-20-2020, 09:24 PM | #7 |
Re: cylinder bore
I have seen .040taper, still standard at bottom --original pistons with expanders, you need to measure at the bottom too
If you don't have the measuring tools measure the end gap of a piston ring, move it to bottom ,measure gap, 1/3 of the difference will be close to the taper |
