Old 05-29-2021, 07:38 AM   #1
marty in Ohio
marty in Ohio's Avatar
Default straight front bumper
My '30 town sedan has a very nice front bumper but it's completely straight. I've had the car for almost 30 years and the bumper has always bothered me. At a swap meet a couple weeks ago someone was selling a bumper with the slight curve to it but the surface was not as good as mine. I got to wondering if mine could be bent to the right curve. Anybody ever done this?
Marty
marty in Ohio is offline   Reply With Quote
Old 05-29-2021, 07:49 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: straight front bumper
Sure, I’d use a press.
However bending anything that’s chromed can jeopardize the chrome. Could crack
Oldbluoval is offline   Reply With Quote
Old 05-29-2021, 07:53 AM   #3
Oldgearz
I used a Harbor Freight press and blocks of wood to carefully recurve mine. Took patience and multiple efforts to get both bars the way I wanted them, but it came out okay.
Oldgearz is offline   Reply With Quote
Old 05-29-2021, 08:29 AM   #4
ronn
sell yours and buy another........
Old 05-29-2021, 06:00 PM   #5
Model A Ron
Model A Ron's Avatar
You could very well damage it. I would take the above advice in my opinion.
Model A Ron is offline   Reply With Quote
Old 05-30-2021, 06:58 AM   #6
marty in Ohio
Thanks for the thoughts. Now that I think more about it, I've decided that I'm the only one who has noticed that the bumper doesn't have a curve to it. I guess if it "ain't broke don't fix it."
Marty
Old 05-30-2021, 09:04 AM   #7
shew01
shew01's Avatar
There is often a lot of value in that statement.
shew01 is offline   Reply With Quote
Old 05-30-2021, 09:30 AM   #8
Will N
Will N's Avatar
Mi bumper was straight too when I acquired it. I went to take it off to bend it, and as soon as I loosened the clamps, the bumper bars sprung back to a curve.
Will N is offline   Reply With Quote
Old 05-30-2021, 10:00 AM   #9
The Master Cylinder
The Master Cylinder's Avatar
And when you tightened the clamps back up did it stay curved?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-30-2021, 10:11 AM   #10
The Master Cylinder
Duplicate.
The Master Cylinder
Old 05-30-2021, 10:38 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Take your front bumper to a spring shop and have them arc it for you. Have the shop add curvature until the straight line dimension eye-to-eye is 62-7/8". Caution the shop about protecting the chrome plating.
By the way, I had an accident years ago that severely bent the front bumper on my Coupe, and the plating did not peel, flake or otherwise fail.
For those of you with a post August 1930 car, the dimension is 62". See the Ford Service Bulletin of August 1930, Page 484.
Bob Bidonde
Old 05-31-2021, 06:01 AM   #12
DkFordor
Bob, where you able to straighten the bumber after the accident?
I myself have a kink in the old bumpers that we couldn't sort out after a (pretty much minor) accident
DkFordor is offline   Reply With Quote
Old 05-31-2021, 09:37 AM   #13
Will N
Will N's Avatar
Yes sir. The bumper bars are quite springy.
Old 05-31-2021, 01:21 PM   #14
Kevin in NJ
I think you need to look closer at what you have first.
Are they a reproduction?
What do the side an back surfaces look like? Take some pictures and post them.
Loosen them and see what they do. When they are loose try to bend them and see if they bend easy and hold.
Real originals are made of spring stock and will be harder to give a good arch. They will have a 'mill' finish on the back (depending on how it was restored).
Of course it comes down to goals. How do you want your car to look and function? There are many 'right' ways to go depending. Personally I believe a not so pretty original is better then a pretty repro. I think the metal is better and will do a better job as a bumper in any minor bumps.
First start with identifying if these are originals or reproductions.
Kevin in NJ is offline   Reply With Quote
Old 05-31-2021, 01:53 PM   #15
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Was the bumper originally straight or curved?
I have a stainless repo, and after a front end collision I straightened it and buffed it, and when I put it back on, it has a curve, which I like. But I’ve often wondered if it supposed to be straight? You certainly see both!
Old 05-31-2021, 03:51 PM   #16
JOHN CT
JOHN CT's Avatar
I perched a new repop s/s bummer some years ago. And the curve was way too much!! It stuck out and it just didn’t look right. I got some thick rubber mats hung them on a concrete wall put the cari fist gear and adjust them to a nice curve then tightened everything up. So far no problem and they always look good �� But I always wondered if I did the right thing maybe I should have shipped them back
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 06-01-2021, 01:44 PM   #17
Kevin in NJ
Curved, go look at factory picts.
Old 06-01-2021, 03:06 PM   #18
Chuck Sea/Tac
Thanks Kevin: I’m guessing the bumper brackets have a play in the curve!
I just looked in the Ford Model A as Henry built it. Theresa a nice side view of a 31 Vickie. About the same curve as my Tudor.
