Old 09-18-2012, 06:52 PM   #21
columbiA
Default Re: Universal Joint Grease
After driving "A",s for well over 100,000 miles,I have never wore out a U-joint.Ive always used regular winter weight chassis lube.
columbiA is offline   Reply With Quote
Old 09-18-2012, 07:48 PM   #22
Chris H
Chris H's Avatar
After reading about the John Deere corn head grease here last year, I purchased some. I looked at the label after getting home with the grease and found that it is a polyurea soap based grease. (Should have looked at the label first!) I found that the polyurea base is not compatable with the more common lithium or aluminum soap based greases. Being as that I have no idea what the previous owner used in the past I have been reluctant to add any of the corn head grease. Has anyone experienced any problems mixing the greases in the U-joint?
Chris H is offline   Reply With Quote
Old 09-19-2012, 06:17 AM   #23
RockHillWill
RockHillWill's Avatar
I have given this some thought lately as I was asked not long ago regarding the installation of the seal in the torque tube.
I gave the INCORRECT answer by stating that the seal was intended to keep the oil in the rear end housing from going forward. I gave this answer in spite of the fact that I was told an NOS torque tube had the seal installed in a manner that prevented oil from going down into the torque tube.
After thinking about all that I have learned, I have the current thoughts regarding this universal joint lubricating 'situation'.
The universal joint housing has a grease fitting, not a filler plug, indicating that it is supposed to have grease in it. All the u-joint housings that I have seen, the grease residue in it has had the grease formed to the outside edges of the housing indicating that the spinning u-joint has displaced the grease from around the u-joint bearings themselves.
I dis-agree with those that promote putting seals in the transmission bearings if they think that they are stopping the flow of oil out of the rear of the transmission. If you look closely, the shaft that the u-joint mounts to is splined in the area that goes thru the rear bearing, still allowing the oil to go past the rear bearing, just at a slighly higher oil level.
It is my opinion that the u-joint housing is filled with grease first, knowing that it will cavitate around the spinning universal joint, allowing for a smaller amount of the transmission oil required to fully lubricate the u-joint. This oil is supposed to 'leak' thru the rear bearing into the u-joint housing and is prevented from going further downstream by the seal in the front of the torque tube.
If you look at the position of the oil filler plug relative to the u-joint housing and the torque tube seal this becomes a little more clear. I am certainly open to input on this matter if some one has an alternate view.
My apologies to my fellow Fordbarner if you used my input in assembling the torque tube seal in your 'unit', I did not think of it in this manner at that time.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 09-19-2012, 01:09 PM   #24
jerry rose
Smile Re: Universal Joint Grease
At least everyone agrees that lube is essential.
jerry rose is offline   Reply With Quote
Old 05-23-2021, 02:05 AM   #25
Harold Degand
Is another grade 0 grease can do the job ?
Corn head grease is pretty hard to find where I live. Or I’ve to buy a box of 30 tubes !
Harold Degand is offline   Reply With Quote
Old 05-23-2021, 05:44 AM   #26
jayvee34
jayvee34's Avatar
Originally Posted by Mitch Newman View Post
I am going through a complete restoration of a 30 model std coupe. So the reassembly of the drivetrain is currently clean and dry. Reading Les Andrews mechanical book, he states that a "liberal amount" of grease should be pumped into the universal joint area. Just how much is a liberal amount. It looks like you could hold an entire tube of grease in there. How much have you guys used after a dry rebuild?
Recently installed a rebuilt transmission and used about a full tube of Lucas
heavy duty grease.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-23-2021, 06:24 AM   #27
old31
When the car is assembled, you remove the speedometer turtle. This is to give you a visual of how much grease you are installing.
When the grease drips out of the turtle you have pumped in enough grease in the clamshell.
If you don't remove the turtle you will never know how much grease you are pumping in the clamshell grease fitting.
old31 is offline   Reply With Quote
Old 05-23-2021, 06:28 AM   #28
Harold Degand
Thanks for the replies.
Where I live, I can only find NLGI #2 grease.
I went to a JD dealership, they can order it for me but in a box of 12 tubes !
Old 05-23-2021, 07:49 AM   #29
Bob Bidonde
Bob Bidonde's Avatar
I soak the u-joint in motor oil to assure its bearings have lubricant before I install the joint. Then I grease the joint.
Bob Bidonde
Old 05-23-2021, 09:24 AM   #30
rotorwrench
rotorwrench's Avatar
There are actually several different brands of corn header gearbox grease and they are not all the same. Back in the day, Ford called out a mixture of sodium based grease and a basic gear lubricant to a consistency that would be semi-fluid. These older materials don't have a very good resistency to break down if water gets in but they do work. Sodium grease was a common axle grease back through the earlier days of the automobile. Modern disk type braking systems needed grease that could take more heat but sodium based grease is still available. Mixed with a heavier viscosity gear lube or motor oil, it could still function as was intended in the model A era.
Old 05-23-2021, 10:11 AM   #31
Mulletwagon
Mulletwagon's Avatar
If there was ever a need for a pneumatic grease gun -- this is it !!
Mulletwagon is offline   Reply With Quote
Old 05-23-2021, 11:53 AM   #32
jayvee34
jayvee34's Avatar
Very good idea!!!
John
Old 05-23-2021, 11:56 AM   #33
The Master Cylinder
The Master Cylinder's Avatar
I have always wondered, where is all that grease going? I don't see it coming out anywhere?? it states on the Lubrication Chart to lube the universal joint every 500 miles.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
