11-15-2011, 09:51 AM | #1 |
Water based automotive paint
11-15-2011, 10:05 AM | #2 |
Re: Water based automotive paint
Hey ,we are going back in time ,Cad to zinc,much better and no chrome ,how about nickel plating as original?
11-15-2011, 11:31 AM | #3 |
I wonder if being water based means that the metal underneath will eventually start rusting. Or if there is an oil based primer put on first.
11-15-2011, 11:33 AM | #4 |
Look up water based paints.
I believe they are still only doing base coat in water base. The clear coat is currently your normal urethane clear. As I remember reading they are not at being able to do a water based top coat. Do not fear it, it does work from what I have read. They had problems at first, but they are being overcome. |
11-15-2011, 11:57 AM | #5 |
