Old 02-19-2021, 04:17 PM   #1
STAN WHITE
Default Crankshaft seal 59ab
LOOKING FOR HELP ON THE FRONT COVER FOR A 59AB ENGINE CRANKSHAFT SEAL. i HAVE ALWAYS USED THE OLD STYLE ROPE SEAL. THERE ARE NEW STYLE SEALS AVAILABLE, i HAVE TWO ONE IS ALUMINUM WITH AN OUTER O RING THE OTHER IS ALL BLACK IN COLOR. i WOULD LIKE TO KNOW WHICH ONE WOULD SHOULD BE USED. ANY ADVICE WOULD BE APPRECIATED. tHANKS sTAN
STAN WHITE is offline   Reply With Quote
Old 02-19-2021, 05:12 PM   #2
tubman
tubman's Avatar
Default Re: Crankshaft seal 59ab
Use the rope seal. It's the best solution.
Old 02-19-2021, 05:40 PM   #3
flatjack9
flatjack9's Avatar
I use the one piece seal exclusively. Either one will work just fine. I don't have a preference.
Old 02-19-2021, 05:45 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
Stan I like the aluminum one with the outer O ring I found it centers nicely between the pan and front cover especially considering each are somewhat different in shape. Found no leaks at 200 MPH.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 02-26-2021, 04:34 PM   #5
woodja
woodja's Avatar
Send a message via AIM to woodja
Hi guys, new here & wondered if somebody could tell me the years that they had the pin to prevent you from replacing the rope seal from the bottom--
the easy way. Thanxs, Pete
woodja is offline   Reply With Quote
Old 02-26-2021, 04:37 PM   #6
woodja
woodja's Avatar
I should have said that although my car is a '41, the PO said the engine is a '49, but I haven't confirmed that.
