Old 01-26-2021, 11:00 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Power At Rear Wheels
Does anyone have the rear wheel power of a Model "A" from a dynamometer test?
Also, does anyone have engine dynamometer test results of power at the flywheel?
Bob Bidonde
Old 01-26-2021, 11:19 AM   #2
sinbad339
sinbad339's Avatar
Default Re: Power At Rear Wheels
There are crankshaft hp/torque tables for a stock Model A engine and engines with different mods at https://www.modelaparts.net/dynoshee...ynosheets.html
"Our times are characterized by a perfection of means and a confusion of ends." - A. Einstein
sinbad339 is offline   Reply With Quote
Old 01-27-2021, 11:01 AM   #3
Bob Bidonde
Still looking for rear wheel power dyno test.
Bob Bidonde
Old 01-27-2021, 02:30 PM   #4
Jim Brierley
I don't have one for a stock engine but years ago I dynoed my pickup with a mild 2-port Riley. It put 60 HP to the wheels. It was an electric dyno, so I could power the vehicle using the dyno's motor. It took 25 HP to turn the trans and rear end, so about 85 HP at the flywheel.
Jim Brierley is offline   Reply With Quote
Old 01-27-2021, 03:12 PM   #5
jetmek
All it takes is cubic dollars🤑👍
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 01-28-2021, 12:36 PM   #6
Bob Bidonde
Wow! A 25HP parasitic loss in the drive-line seems to be extraordinarily high, and would be terrible if the engine was stock.
Bob Bidonde
Old 01-28-2021, 12:50 PM   #7
McMimmcs
McMimmcs's Avatar
Please tell, what are you gathering these statistics for ?
McMimmcs is offline   Reply With Quote
Old 01-28-2021, 01:08 PM   #8
denis4x4
denis4x4's Avatar
Like Jim, I ran 60HP at the rear wheels on a chassis dyno at the Speedster Reunion in Lincoln.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-28-2021, 03:23 PM   #9
Big hammer
It takes hp to move 600w oil 🙃
get a bigger hammer tap done
Old 01-28-2021, 03:50 PM   #10
Synchro909
Synchro909's Avatar
It sure does. That thick oil is like a hydraulic damper. I run lighter oil in the diff for that reason but stick with the heavier oil in the cog box. Light oil makes gear changing more difficult.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-29-2021, 12:31 PM   #11
Bob Bidonde
McMimmcs, I am the Technical VP in my local "A" club, and I give slide presentations at every club meeting. I concentrate on info not previously published, so I collect data and stats wherever I find stuff that passes my engineering giggle test. If you would like to see some of my presentations, look here
https://www.modelalongisland.com/
Bob Bidonde
Old 01-29-2021, 12:54 PM   #12
Jack Shaft
https://www.powertransmission.com/is...ing-losses.pdf
This is very techie but if you read between the lines you can see where Jim's hp losses are generated from flywheel to road wheels. Sliding gear teeth design even has a factor, spur cut A transmission gears have a higher loss than later helical cut gears.. even oil has a friction element to it.
Jack Shaft is offline   Reply With Quote
Old 01-29-2021, 01:05 PM   #13
McMimmcs
McMimmcs's Avatar
Thank you, I was wondering if my A.’s needed some kind of adjustment.
