Old 03-08-2024, 03:32 PM   #1
SoCal32
Default 32 firewall differences?
Was told there's an early and late. I have a couple that have differences on the driver's side.
SoCal32 is offline   Reply With Quote
Old 03-08-2024, 03:41 PM   #2
rockfla
rockfla's Avatar
Default Re: 32 firewall differences?
There were more than just two, perhaps DavidG's post last in this thread will help you best!!! Your right hand photo is the "early" version for sure
https://www.fordbarn.com/forum/showt...ll+differences
Old 03-08-2024, 03:46 PM   #3
Krylon32
I've had a bunch. I always was told the one in the red primer was an early? and the other one came a little later.
Krylon32 is offline   Reply With Quote
Old 03-08-2024, 03:47 PM   #4
rockfla
rockfla's Avatar
Correct
Old 03-08-2024, 04:34 PM   #5
SoCal32
Thanks for the info
Old 03-08-2024, 04:35 PM   #6
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 03-08-2024, 05:47 PM   #7
DavidG
DavidG's Avatar
I've observed eight visibly different LHD firewalls (Ford labeled them "dashes" in the day) and six visibly-different RHD versions and there may have been more.
In the photos in #1 above, that in the second photo with the depressed area meant to accommodate the vacuum storage tank for the never-released vacuum-assisted clutch is the second or third version depending on other features on the dash. The first photo is that of the most common version with additional space on the inside to increase the amount of toe room around the clutch pedal when depressed.
