Old 02-06-2024, 02:28 PM   #1
metro1
Default Under hood Insulation
I assume my 59 Galaxie had insulation under the hood at one time. Does it need to be replaced? If so with what? I'm not making a "show car" just a driver so I really don't care about the appearance.
metro1 is offline   Reply With Quote
Old 02-06-2024, 11:17 PM   #2
fordor41
fordor41's Avatar
Default Re: Under hood Insulation
Our '60 Fairlane doesn't show signs of any insulation. Was some in the trunk lid but was mostly gone. removed remaining and replaced it with undercoat to appear correct. problem is the undercoat is so heavy lid won't stay up!!
fordor41 is offline   Reply With Quote
Old 02-07-2024, 10:40 AM   #3
metro1
Thanks for your answer. I was looking at some discussions online and it seems to be some for and some think it isn't necessary. I think I'll just repaint it and move on.
Old 02-08-2024, 01:49 PM   #4
40cpe
40cpe's Avatar
My '55 originally had insulation under the hood over the exhaust manifolds. The person who painted the car before I got it didn't replace it. It has been several years and there is no damage to the paint under the hood.
40cpe is offline   Reply With Quote
Old 02-08-2024, 02:28 PM   #5
metro1
My main concern was the heat. I bought a qt. of high heat black paint just in case. I'll just spray several coats of that. Thanks for your reply.
Old 02-08-2024, 03:41 PM   #6
Late model
Late model's Avatar
The 19-49 Ford factory parts manual does not show insulation used in the hood, only a a extrusion that is installed on the cowl to seal the hood to the cowl.
Late model is offline   Reply With Quote
Old 02-08-2024, 07:11 PM   #7
metro1
Apparently heat is not issue. I saw it mentioned once that it could also be for noise reduction which I don't care about.
Old 02-14-2024, 01:18 PM   #8
JimNNN
Speaking of this stuff...what is the best adhesive to use to keep under hood insulation attached to the surface? I used the tackiest stickiest spray-on adhesive I could find, but the insulation eventually came off, presumably from the high temps. I used a couple lesser spray-on adhesives before then which didn't work well at all, even in the short term. This was on my Thunderbird.
JimNNN is offline   Reply With Quote
Old 02-14-2024, 06:12 PM   #9
KULTULZ
KULTULZ's Avatar
Look at this - https://www.3m.com/3M/en_US/p/d/b40069451/
Make sure the under hood panel skin is clean (maybe wipe down with prep-sol) and masking tape the pad(s) to the underside of the hood to let the adhesive fully set. Leave hood opened maybe to allow adhesive to fully set before applying weight (hood closed).
This is a 55/57 BIRD?
KULTULZ is offline   Reply With Quote
Old 02-14-2024, 06:18 PM   #10
KULTULZ
KULTULZ's Avatar
... it could also be for noise reduction
That and at some point, under-hood heat may affect the outer finish.
Old 02-14-2024, 06:28 PM   #11
KULTULZ
KULTULZ's Avatar
Arrow Re: Under hood Insulation
Are there torsion bars on the '60 (I can't remember)? If so they are adjustable.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
Old 02-14-2024, 11:34 PM   #12
JimNNN
Thanks for the link, Kultulz, and the masking tape tip. I'll try that 3M product. My T-Bird is a '65.
As far as the trunk goes, my '61 Mercury trunk has the torsion bar setup, but I don't know about the '60 Fords or '60 Mercuries.
Old 02-15-2024, 03:52 AM   #13
KULTULZ
KULTULZ's Avatar
Red face Re: Under hood Insulation
I'm sorry, that was meant for fordor41 ...
Old 02-15-2024, 10:37 PM   #14
fordor41
fordor41's Avatar
Yes, there are tension bars. Haven't gotten the guts to try and adj. them yet. Looks "easy" in the Ford manual. We'll see!!
