Old 06-21-2022, 09:55 AM   #1
rockfla
rockfla's Avatar
Default Where or what a the difference in 35 sedan Vs Coupe rear fender
Is the difference in 35 sedan Vs coupe fenders in the inner width of the fenders where they mount to the body, is it in the shape of the wheel arch/opening OR is it both?? OR phrased another way…..IS it possible to make a sedan fender fit a coupe with some modifications IF need be???
Old 06-21-2022, 11:33 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Where or what a the difference in 35 sedan Vs Coupe rear fender
To make a sedan fit a coupe,a strip had to be added on the body side. It starts out wider in the center by 1.25" and tapers towards the front and the back.I have done it.
deuce lover is offline   Reply With Quote
Old 06-21-2022, 02:40 PM   #3
Brian
Brian's Avatar
https://www.fordbarn.com/forum/showt...der+difference
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 06-21-2022, 03:01 PM   #4
rockfla
rockfla's Avatar
Thank for the help guys, Sheldon I "think" strongly it will take a sedan fender after looking at the above post again.
Old 06-21-2022, 04:20 PM   #5
Karl Wescott
Karl Wescott's Avatar
Another important difference (if you try to convert a sedan fender to coupe) is that the sedan fender is taller by about 1" from the bottom of the fender to the top dead center. Just complicates things the better you try to make the fender.
Karl Wescott is offline   Reply With Quote
Old 06-22-2022, 09:16 AM   #6
RalphM
RalphM's Avatar
My 35 coupe right rear fender is a sedan fender. They cut the original fender about 4 inches from the body and grafted on the sedan fender.
The mounting holes for the sedan fender can still be seen underneath the seam overlap. It was all leaded in A’s well. It’s not a straight cut either, it moves toward the body as it goes back.
RalphM is offline   Reply With Quote
Old 06-22-2022, 09:19 AM   #7
RalphM
RalphM's Avatar
Here is the underneath.
File Type: jpeg A8B1D30A-3E7A-4089-A3C7-4BDEF36404B7.jpeg (120.1 KB, 26 views)
File Type: jpeg AFDC15D3-1B29-437F-9DD1-3C189C33BEC3.jpeg (113.5 KB, 22 views)
Old 06-22-2022, 09:24 AM   #8
RalphM
RalphM's Avatar
And it does not look that bad if done properly.
File Type: jpeg 69238CE3-09D4-4E3A-9E8E-B27870364EEC.jpeg (132.1 KB, 20 views)
