10-31-2021, 09:29 PM | #1 |
lifter / lifter boss question
to hold the adjustable type lifter while doing the adjustment the cam has to be rotated, adjusted then rotated back and the clearance checked.
the question is is there a modification that can be done to the lifter boss to hold the lifter from turning so the trial and error is not necessary? i know we are looking at a totally different style lifter but, for eg. on a flathead 8 a hole is drilled into the lifter boss and a pin will hold the lifter during the adjustments. thanks
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
11-01-2021, 07:23 AM | #2 |
Re: lifter / lifter boss question
A lot of engines have the lifter bosses (guides) milled down so that the lifters are accessible when the lifters are on the heals of the cam lobes. I realize that this is not possible to do when the engine is together but it may be something to plan next time the engine is rebuilt.
11-01-2021, 08:00 AM | #3 | |
is there an info on how much to take off of the top of the lifter boss? thanks
11-01-2021, 08:20 AM | #4 |
i guess that amount could be measured by, with the cam and lifter in, and on the heal, measure the height needed to access the holding flats.
i wonder how much material is acceptable to remove. seams to be lots of length to that lifter guide.
11-01-2021, 08:20 AM | #5 |
I have not seen any data but I would take off just enough to clear the location on the lifter where you need to grab onto it with the wrench. I use skinny wrenches.
11-01-2021, 11:56 AM | #6 |
11-01-2021, 12:07 PM | #7 | |
the benefit would be for the next owner or if there is some sort of failure. i may or may not shorten the lifter bosses i have not decided yet. if i do, for me this is the time to do it as the engine is completely torn down and will be heading off to mr Babbit soon. time is not an issue for me, was curious if there was an easier way. thanks
