07-15-2021, 04:05 PM | #1 |
Front brake adjuster question
Can anyone advise the tap size for the brake adjuster wedges used in all four wheel backing plates???
Bob from Northport Northport, Michigan |
07-15-2021, 05:05 PM | #2 |
Re: Front brake adjuster question
5/8-18. Tap is available from McMasters-Carr
07-15-2021, 10:26 PM | #3 |
Thanks!!
07-16-2021, 06:55 AM | #4 |
The threads in the backing plate that Ford put in must have been to a different standard because a modern 5/8-18 bolt will not go in. If you installing a Flat Head Ted kit you must re-tap the threads.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 07-16-2021 at 08:51 AM. Reason: spell check |
07-16-2021, 07:55 AM | #5 |
We have a car in my shop that the brake components are so badly rusted we are having real problem getting anything apart and cleaned up to rebuild. The brake pins and rollers are even frozen solid.
Thank You!!
07-16-2021, 08:53 AM | #6 |
Dragging my foot slows the car down more than standing on the brake pedal.
07-16-2021, 12:07 PM | #7 |
Soaking in lacquer thinner, then penetrating oil, then using heat.
I lived in Asheville for 20 years.
07-16-2021, 06:05 PM | #8 |
Asheville is a great town. My wife and I love it. For those who do not know, it is a mountain community with lots of resident artists. There are some very interesting art galleries in town and some great restaurants. See https://en.wikipedia.org/wiki/Asheville,_North_Carolina
