Old 09-02-2019, 06:09 PM   #1
mrtexas
mrtexas's Avatar
Default 49 windshield install
Installing a new windshield rubber on my 49 woodie. The rubber comes in two pieces. Had it 99% done and discovered the center rubber pieces didn't line up good enough. So I worked both glass's a little to the center. Had to trim off a little metal on the rubber stainless inserts to make them fit as well. The 41 had a one piece rubber which was way easier to install. Wooden spacers are holding the stainless in place until I can install the center rib which is the last step in the process. Still need to install the inside pieces.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
