09-03-2019, 08:55 PM | #21 |
Re: 32 rear trans support/torque tube cap bolts
Here are some pictures. The black bolts are the correct for '32. I think the nut is as well, regardless its the smaller sized one.
The "plain" bolt (longer version used in later cars ('35-'36?) and new nut are what David was talking about. It's hard to tell while on the bench, but once threaded on, the new nuts are just about touching the "clam shell". |
09-03-2019, 09:47 PM | #22 |
Can you attach a side profile photo of the nuts?
09-03-2019, 09:54 PM | #23 |
Make SURE you check the fit,I have just pulled another 33 apart,.044 up and down play in the cap,both bolts and housings worn.
So the trans and driveshaft are not in the same centre Lawrie |
09-04-2019, 04:28 AM | #24 |
Sure, Michael.
09-05-2019, 04:55 AM | #25 |
Without calipers or a mic, just find the ones that a 5/8 wrench or socket fit on.
