Old 09-01-2019, 02:20 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 6v Generator Swap
Have a 6v generator with mounted fan. Its suspect but have a 46 generator.
Will it fit with the swap of the front cover with mounting plate?
Both being 2 brush type.
thanks,
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 09-01-2019, 06:59 PM   #2
Phil Gillespie
Default Re: 6v Generator Swap
Have since checked and armature from 46 generator is not long enough. So will have to go with a correct style replacement armature for the 39 generator.
Phil NZ
Old 09-02-2019, 02:14 PM   #3
G.M.
I have adapted the 36 fan to the 39 generator. Had to make an adaptor. It's
been on the car 35 years and at least 50,000 miles. I set it up with a dial
indicator. Here are two I did. These were six bladed industrial blades still working good. G.M.
www.fordcollector.com
