Old 03-18-2024, 03:12 PM   #1
jers36
jers36's Avatar
Default Compression questions
I am trying to find what is causing overheating problems on my 36 pickup with the original stock engine. I thought I had it solved last fall but it is acting up again. I bought a new compression gauge and checked the compression trying to determine if I had a blown head gasket. This is my readings from 1-8, 70-65-65-80-70-60-70-70. The truck runs fine except for the over heating, I have read on some previous sites here that this not the best but if it isn't broke don't fix it. I am going to get one of those combustion leak detectors that you put a chemical in it and if it changes color when exposed to combustion gases you could have blown head gasket cracked block etc. as a double check. What do you think of the compression readings? Thanks
jers36 is offline   Reply With Quote
Old 03-18-2024, 03:19 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Compression questions
Remove the upper hoses then remove the belt so the pumps can’t turn. Then fill the engine with water via the water necks until you can see a level. Then start the engine and look for bubbles in the water necks. That will tell you if it’s leaking and which side.
Old 03-18-2024, 03:42 PM   #3
Lawrie
Lawrie's Avatar
And if you give it a rev and see bubles,you can short out each plug and find the cylinder that has the leak
Lawrie
Old 03-18-2024, 03:56 PM   #4
jers36
jers36's Avatar
My water pumps are on the top front of the heads I don't think that will work.
Old 03-18-2024, 04:44 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Watch the water levels in the water outlets of the water pumps on your heads. You need to have the block and radiator as full as the pump outlets so you can watch the water for bubbles in the pump outlets. You can add additional length of hose to the pump outlets and watch the water that way as well.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-18-2024, 04:51 PM   #6
Ol' Ron
Ol' Ron's Avatar
Learn sumpin every day. great forum here!!
Old 03-18-2024, 05:07 PM   #7
Ken/Alabama
Or clamp a balloon or rubber glove on the water necks and see if they start blowing up.
Old 03-18-2024, 05:36 PM   #8
rockfla
rockfla's Avatar
Ken
Saw this the other day on a Facebook page, was gonna say, why go through all the trouble of taking the hoses loose, just put a nitrile glove/surgical type glove on the neck of the radiator and crank it up and run it, if it inflates? You got problems !!
Old 03-18-2024, 05:57 PM   #9
Brian
Brian's Avatar
Any pressure build up from a compression leak will simply vent outta the overflow tube if you put the balloon on neck of radiator!
Old 03-18-2024, 06:34 PM   #10
Ken/Alabama
Must put it on the water necks on the engine
Old 03-18-2024, 08:23 PM   #11
Brian
Brian's Avatar
I know, my answer was to rock
Old 03-19-2024, 08:07 AM   #12
Bored&Stroked
Bored&Stroked's Avatar
Hell, might look like the "hand of the proctologist" sticking above your radiator . . . a new type of "ornament" for age old hot rodders. LOL
Bored&Stroked is online now   Reply With Quote
Old 03-19-2024, 08:16 AM   #13
rockfla
rockfla's Avatar
EASY, just plug the drain tube off!!!
Old 03-19-2024, 08:23 AM   #14
Seth Swoboda
Seth Swoboda's Avatar
The compression readings are a little low. Tell us more about your engine. Did it sit for a long period of time (years) before you started to run it? What is the condition of your radiator? How are the fins, are they smashed flat? Did your radiator sit without coolant for a long period of time? Is the inside of your engine block rusty? What about your distributor, is it properly timed?
There are a lot of questions, along with the possiblility of a bad head gasket.
Old 03-19-2024, 08:31 AM   #15
rockfla
rockfla's Avatar
Seth
I had ALL those questions AND "ARE there any thermostats in the system?" from the very start of the post
Old 03-19-2024, 08:45 AM   #16
Seth Swoboda
Originally Posted by rockfla View Post
Seth
Some of the cars I have I bought after they had sat for decades. The engine blocks and radiators were long dried out and full of crusty, rusty, scale and dirt. A good cleaning was in order. Also, on one occasion I had to have the radiator rodded out. On another, I bought a NOS service replacement radiator.
On all of them I had the distributors rebuilt and timed.
I have found that a flathead will cool and work fine when all of these systems are working at 100%.
As for the low compression, I put over 1200 miles on a 21 stud with similar compression readings last summer before I pulled the engine and installed a rebuilt engine. It used a lot of oil but I was having fun.
Old 03-19-2024, 07:15 PM   #17
jers36
jers36's Avatar
Seth in answer to your question yes this truck has been sitting idle for most of it's life. The guy I bought it from owned it about 5 years. The first year he owned it he had the gas tank cleaned and sealed and the mechanical brakes completely gone thru and rebuilt. He went to some early ford V8 meetings decided that was not his thing and I think just left the truck set in his garage for the next 4 years. I spoke to the owner prior to him and he owned the truck for about 30 years and he said he only drove it around his neighborhood occasionally. That owner bought it from a guy in Georgia who was old and selling his car collection. So setting idle most of the time has taken a toll.
Today I backed it out in the driveway opened the petcocks on the block and put a hose in the radiator and flushed the block for about 30 minutes. It flushed brown water for a little bit and then cleared up. I flushed it last year and put prestone antifreeze in it with some cleaner but that's not what it looked like today. I don't want to pull the engine and rebuild it if I don't have to, it probably has babbit bearings and that could get exspensive.
Old 03-19-2024, 07:30 PM   #18
jers36
jers36's Avatar
I forgot to mention the radiator looks pretty good there are no damaged fins they look even and straight, I did see two small places that were repaired but look fine and are not leaking. I put distilled water in it today. I could only put in 14 quarts and it would heat up spit out a little in the overflow tube. Its supposed o take 18 quarts. Will the block fill up with water from the upper and lower hoses on the radiator?
Old 03-19-2024, 07:59 PM   #19
Ken/Alabama
Or some XX Large Trojans !!
Old 03-20-2024, 09:05 AM   #20
Seth Swoboda
Jers36,
You might want to remove the top and bottom radiator hoses. Use a garden hose and flush the engine block as well as you can. Try to remove as much loose crud as possible. It might also be worth your time to do a flow check on the radiator. With the hoses removed you can fill the the radiator and observe the rate of flow coming out the bottom. This is kind of subjective but you should be able to tell if the flow is slow or fast. Shine a light inside of the radiator tank and see if any of the tubes are blocked. I'm willing to bet many of them are.
I have this problem with every engine I start after they have sat for a long time.
I'm not discounting the possibility of the bad head gasket. That is worth a check also. I have never had that problem....yet. Or perhaps you have a crack in the block near a valve?
Also, you'll eventually need to put some miles on the engine to try and get the rings to seal better. You might use a liberal about of MMO in the gas for a while.
Don't give up. When you solve your overheat issue, you will want to drive that old truck everyday.
