Old 02-14-2024, 06:49 PM   #161
KULTULZ
KULTULZ's Avatar
Exclamation Re: New seal for PS ram.
Originally Posted by Merc Cruzer View Post
I was at the local club auction this Fall and found another one. No one knew what it was, so I was able to pick it up for $10.00. Brought it home and hooked it up and it ran perfectibility. So I cleaned it up and now I have a backup.
Not bad, considering the one on e-bay is "UNTESTED"
- AND THE SEA PARTED -
Here is some more info on Trico Electro-Vac Booster Pump -
https://www.mercuryclub.com/2017/03/...ercury-wipers/
There was a 6V and 12V offered.
KULTULZ is offline   Reply With Quote
Old 02-14-2024, 07:09 PM   #162
KULTULZ
KULTULZ's Avatar
Originally Posted by KULTULZ View Post
I hate to be a party-pooper, but ...
I would have tried the end seal kit to see if it would stop the leakage. Don't forget the boot.
The INTERNAL SEAL controls pressure/movement within the cylinder.
If that seal fails, the cylinder fails.
The END SEAL controls leakage/dirt intrusion at the cylinder piston extension.
It can leak (common) and that is what you see on your garage floor.
GIGGLE C1AZ 3C651-A
- AGAIN, THE SEA PARTS AND THE BOY SEES THE LIGHT -
... dumba$$ ...
Had a flash. Doubt the FORD SEAL KIT would work on an aftermarket cylinder ...
... The BLUE PILLS ... Honey. where are they?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
Old 02-16-2024, 04:43 PM   #163
Gene F
Gene F's Avatar
Default Re: New seal for PS ram.
I had a 1st generation Mustang with a Ford unit. Sooner or later they all leak, and re-leak. Just my experience.
Old 02-17-2024, 12:06 AM   #164
KULTULZ
KULTULZ's Avatar
Post Re: New seal for PS ram.
An integral box/system is also going to leak at some point.
