Old 01-08-2024, 12:50 PM   #1
nitro-express
Default Alternator that looks like a generator. Is there such a thing.
I have a passing interest in the older Fords, the flathead V8 and the Y block engines.
In my limited experience with the generators and 6v, I was wondering if anyone has made an alternator that looks the same and replaces a generator.
I suppose an alternate solution would be to gut a generator and fit an alternator into the generator housing.
NE
nitro-express is offline   Reply With Quote
Old 01-08-2024, 01:03 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Alternator that looks like a generator. Is there such a thing.
Welcome aboard! Yes, one such company is E. J. Whitney Co., Inc. in California that does generator to alternator conversions. https://ejwhitneyco.com/automotive.html
Zeke3 is offline   Reply With Quote
Old 01-08-2024, 01:03 PM   #3
corvette8n
corvette8n's Avatar
Speedway has them among others.
If you fix the issues with your original equipment you should be good to go. My ‘41 is still 6 volt with a generator and it’s still chugging after 83 years.
Old 01-08-2024, 01:54 PM   #4
drolston
drolston's Avatar
The PowerMax looks like a generator but is about 3/4" larger diameter than a stock generator. I did not last long. I took it to a generator shop who figured out that the polished aluminum generator-looking housing contained a small alternator from a Japanese car. They found a suitable replacement alternator to fit in its place, and that has been working okay for about four thousand miles.
Old 01-08-2024, 02:09 PM   #5
john in illinois
john in illinois's Avatar
I have a Whitney 12 v alternator on my roadster. He uses an original case and bearings so it can safely support a fan. Makes 6 V too.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 01-08-2024, 02:51 PM   #6
petehoovie
petehoovie's Avatar
John
Old 01-08-2024, 06:55 PM   #7
nitro-express
Thanks.
Old 01-08-2024, 08:17 PM   #8
dean333
dean333's Avatar
Send a message via Yahoo to dean333
No personal experience but I have heard the alternator/generator look alikes don’t vent effectively therefore prone to overheating and failure. That’s the reason I decided against one for my 33.
Tim Carlig
dean333 is offline   Reply With Quote
Old 01-09-2024, 07:40 AM   #9
deuce lover
deuce lover's Avatar
FYI,The Whitney units have an entirely new case.He does not use the old ones,only the front and back plates.
Old 01-09-2024, 09:48 AM   #10
Pat/Ohio
Pat/Ohio's Avatar
I have a 12v generator style alternator on my '51 Victoria.
Pat
Pat/Ohio is offline   Reply With Quote
Old 01-09-2024, 10:36 AM   #11
Automotive Stud
Automotive Stud's Avatar
I have a powermaster on my '47 and a Whitney on my roadster. Both perform well but I must say the Whitney is much more convincing looking. It uses a factory rear plate and the front mount and pulley look original. I have a generator on my '40 and that works fine aswell.
Automotive Stud is offline   Reply With Quote
Old 01-09-2024, 10:57 AM   #12
john in illinois
Yes I forgot he uses a new aluminum case with the ford back and front and Ford bearings fitted.
John
Welcome each day
Old 01-09-2024, 11:58 AM   #13
petehoovie
petehoovie's Avatar
Pat
Old 01-09-2024, 01:04 PM   #14
51woodie
51woodie's Avatar
I have a Powermaster 82016 6V Neg. ground on the 59AB in my '46 Coupe. It has 5000+ miles on it with no issues so far. I have kept the original wiring and regulator in place, and had the generator rebuilt for spare. Will likely change back to the gen. if the alternator goes south.
https://www.jegs.com/i/Powermaster/713/82016/10002/-1
51woodie is offline   Reply With Quote
Old 01-09-2024, 05:27 PM   #15
aussie merc
aussie merc's Avatar
power gen have got them selves a bad name over here due to their warranty attitude less and less outlets are handling them now [dont want to know about it and you did something wrong ]
aussie merc is offline   Reply With Quote
Old 01-09-2024, 08:58 PM   #16
Charlie Stephens
NE
To answer your specific question, YES, but I prefer a properly rebuilt original generator unless you have accessories that require a lot of power.
Charlie Stephens
Old 01-10-2024, 03:00 AM   #17
Karl
Karl's Avatar
Yep The original 33 generator I had on my early 34 fordor had no built in cooling vanes at the front -Whitney refused to make an alternator using the 33 casing due to the risk of overheating -We used a 34 generator casing with the inbuilt cooling vanes and it has been going strong for 6 years
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 01-10-2024, 10:05 AM   #18
Shoebox
Shoebox's Avatar
I have a '32 roadster that has an original AC Delco generator that has alternator guts, the car is not proper for here as it has a Buick nailhead and is a highboy. The conversion was done by GenerNator and has worked wonderful for about 10 years. You might want to check their website.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 01-10-2024, 03:56 PM   #19
ndnchf
ndnchf's Avatar
I don't think anyone would argue that that an alternator is not a technological improvement over a generator. But for how most people drive these cars today, the question is - do you really need the technological improvement? Especially today with quality LED head and tail lights. The extra current available from an alternator may not be needed. For some it is, I have no problem with that - to each his own.
I rebuild original Ford generators just for fun, I know them pretty well. They are very high quality. When properly rebuilt and set up correctly, they will provide many years of trouble free service. This is an example of one I rebuilt recently.
ndnchf is offline   Reply With Quote
Old 01-10-2024, 04:31 PM   #20
drolston
drolston's Avatar
Originally Posted by ndnchf View Post
I don't think anyone would argue that that an alternator is not a technological improvement over a generator. But for how most people drive these people cars today, the question is - do you really need the technological improvement? Especially today with quality LED head and tail lights. The extra current available from an alternator may not be needed. For some it is, I have no problem with that - to each his own.
Is there any way to rework a '41 6v positive ground generator to put out 12v negative ground? With a proper regulator, of course. Or does anyone sell such a generator/regulator combination?
