Old 11-08-2021, 03:32 PM   #21
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Does the oil pump bolt have to be safety wired?
Originally Posted by JM 35 Sedan View Post
Good advice in general Ronnie, and especially good advice for anyone attempting a record run at Bonneville @ 200+ mph. What was your approximate engine rpm @ 205.744 mph?
We geared it for 6500 RPM data shows on the run engine reached 6480.
With the gear change on out test run for 2022 mile 4 speed was 219.8 RPM was 6200.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
