04-30-2020, 11:18 AM | #1 |
Oil Pump Pickup
Take a look at the new oil pump pickup on the left compared to original on the right. The pickup tube is shorter on the new one , I’m somewhat reluctant to use it ..Thoughts ??
04-30-2020, 11:50 AM | #2 |
Re: Oil Pump Pickup
Why would you not use a Original Ford part over a repop. Just my 2 cents.
Cobbie |
04-30-2020, 12:17 PM | #3 |
Re: Oil Pump Pickup
Typical import junk. The last tube cut was to short so they went ahead and used it anyway when welding everything together. Send it back its junk the tube needs to be longer so the siphon effect works correctly in the cup.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
04-30-2020, 01:21 PM | #4 |
Re: Oil Pump Pickup
04-30-2020, 05:11 PM | #5 |
Re: Oil Pump Pickup
I would surely use the original one - or I would weld an 'extension' on the repop one.
05-01-2020, 10:00 AM | #6 |
Re: Oil Pump Pickup
