02-11-2019, 02:33 PM | #1 |
DEAD: 1948 Super Deluxe 8 Sedan
My first post here on the Ford Barn, so I apologize if it's a little long winded...
*my background* I have older Fords cars/trucks from 60's-90's. I'd classify them as good summertime drivers, decent, but nothing show quality. I wanted to get something I would consider nice to everyone that would see it... something that the wife and I could take our parents/or friends out in, for a cruise or out to dinner for the night. Mustang GT's or old Ford trucks weren't cutting it, so I was on the look out for something (Ford of course) full size, classic and not modified, but plain old factory stock. I was looking for a nice 60's-70's Lincoln Continental, or a full size Ford from early 70's and older. I came across a 1948 Ford Super Deluxe 8, 2-door sedan that was exactly what I was looking for. Went and inspected it, and was very happy with what I seen (no rust anywhere, no leaks and good paint, tires, brakes) We negotiated down to my price range, and I bought it, and took it home. It runs great (59ab flathead) and it drives just as good as it look. Only there is a few hang ups to work out... When you would start it, it starts right up and runs great, but after it warms up (operating temperature * 10 minutes) if you shut it off, it will no longer start/run for about an hour. It just turns over, and won't fire. Let it sit for an hour, and it fires right up and again runs great. It was like that all summer. Now this fall, I was going to pull it out of the barn so I could jockey around cars for winter storage, and it would not start at all. It turns over fine, but just would not attempt to run what so ever. Last edited by Pigpen; 02-11-2019 at 04:26 PM. |
02-11-2019, 02:43 PM | #2 |
Re: DEAD: 1948 Super Deluxe 8 Sedan
Have the coil or condenser been replaced recently?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
02-11-2019, 04:00 PM | #3 |
02-11-2019, 04:04 PM | #4 |
My avatar although not stock had the same problem when I got it. Turned out the coil was bad.
02-11-2019, 04:07 PM | #5 |
02-11-2019, 04:52 PM | #6 |
02-11-2019, 04:58 PM | #7 |
Is it getting fuel? Crank it over a couple times, then look in the carb and move the throttle and see if there’s fuel squirting in. Check for spark at the plugs. Report back with whatever one you don’t have......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
02-11-2019, 05:21 PM | #8 | |
02-11-2019, 05:49 PM | #9 |
During some of the "hot no start" condition, i did dump some fuel down the carb, and another time tried a squirt or two of Ether, and it didn't make a difference. So I'd assume it's and electrical/ignition problem when warmed up?
02-11-2019, 05:52 PM | #10 | |
02-11-2019, 06:41 PM | #11 |
Welcome to the ‘Barn. And the fun with flatheads. Replace things one at a time following advice give here and hopefully you’ll be up and running, havin fun again. Mike
02-11-2019, 06:42 PM | #12 |
I think you’re on the right track with it being an electrical issue.....have you checked all the suggestions in post #8 ?........Mark
02-11-2019, 07:16 PM | #13 |
Is the cranking speed slow when warm? I went through that, and it was a resistance issue. If it is cranking slow you may not be getting sufficient voltage to the coil while cranking. Mine was an issue with the cable to the starter but grounding issues are more common. My point is, if it is cranking slow you are using too much voltage cranking to supply enough voltage to power the coil.
Tommy |
02-11-2019, 07:41 PM | #14 |
Another please tell us your location request.
02-11-2019, 07:43 PM | #15 |
02-11-2019, 07:45 PM | #16 |
02-11-2019, 07:51 PM | #17 | |
02-11-2019, 07:53 PM | #18 |
02-11-2019, 07:57 PM | #19 |
It’s cold out in my barn too!!!!......so I stay in the house on this “Barn”.......you’ll love it this spring when your driving it!!!....Mark
02-11-2019, 08:15 PM | #20 |
Are you sure you have the right size battery cables? 6 volt uses the larger cables and many times they are replaced by the smaller 12 volt cables. Smaller cables = resistance.
