09-10-2017, 08:50 AM | #1 |
52 Ford F1 engine ground location
On a 52 F1, where is the correct engine ground location, the cable from the battery to the 8BA v8 engine?
JB |
09-10-2017, 11:55 AM | #2 |
Re: 52 Ford F1 engine ground location
Mine goes to one of the bolts that holds the starter plate to block.
09-10-2017, 01:34 PM | #3 |
Thanks, is it the one I have pictured?
09-10-2017, 02:30 PM | #4 |
You can hide them if you wish, but I use flat braided cable to also go from motor to frame and motor to body, I figure you can't have too many grounds.
09-11-2017, 09:42 AM | #5 |
Your picture is where mine was connected when I got the truck 11 years ago.
09-11-2017, 01:53 PM | #6 |
09-11-2017, 01:59 PM | #7 |
Grounds -grounds -grounds
09-11-2017, 05:48 PM | #8 |
Don't forget to scrape or sand that engine paint from the area where your cable will contact the block. That bolt is sliding through the hole and is not threaded. Get the best ground possible like "nbrskn" said.
