Old 03-12-2014, 05:45 PM   #1
smurph
smurph's Avatar
Arrow Need advice on '35 Ford Cabriolet exhaust system
I recently purchased a restored '35 Ford Cabriolet. It has dual exhausts with Red's Headers and Smithy mufflers. Other than this modification it is all stock. To accommodate the driver's side exhaust, the restorer moved the battery to the floor of the rumble seat area and ran the exhaust pipe through the battery box. I am not happy with this arrangement and would like to return the battery to its proper location while maintaining the dual exhausts.
I called Red 's Headers and they make an exhaust pipe that attaches to the header and curves around the battery box to the muffler. They also said some cutting may be required to make it fit.
Has anyone had any experience doing this ? Is there any other way this can be accomplished? Any advice would be appreciated.
Many thanks in advance.
Smurph
smurph is offline   Reply With Quote
Old 03-12-2014, 06:04 PM   #2
AnthonyG
AnthonyG's Avatar
Default Re: Need advice on '35 Ford Cabriolet exhaust system
I am working with Red's same type project and had the same conversation, also didn't like the elimination of the battery box. He indicated if I didn't mind the exhaust under the running boards pipes could be fabricated to get there with no cutting on the car. Obviously the simplest route from their would be exhaust out just in front of rear tires. Still thinking about it my self. I think a local exhaust shop with a good bender could figure out a route under the car without cutting the car up but haven't got that far.
Nomad
AnthonyG is offline   Reply With Quote
Old 03-12-2014, 10:03 PM   #3
G.M.
Smurph
Attached is a picture of a 34 P/U we put duals on. Use an Optima battery and put it in long ways. We made a special battery box. You don't want a battery in the rear. We also mounted an Optima on the right side of the engine on a 35 roadster, again in a special box. Batteries mounted under the floor or in the rear get neglected. G.M.
www.fordcollector.com
Old 03-12-2014, 10:10 PM   #4
FL&WVMIKE
FL&WVMIKE's Avatar
It can be done. Ole SHADETREE has a '35 Cabriolet with the battery in the stock position, with duals. There is a guy, back home, in Spencer, W. Va., that fabricated his exhaust, to fit.
I think that being a Cabriolet, has nothing to do with the fit. I believe that all passenger cars would be the same.
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 03-13-2014, 08:24 AM   #5
Ed Pitts
Ed Pitts's Avatar
Here is the exhaust pipe from Red's that curves around the battery. This is in my 36. The pipe could be wrapped to keep the heat away from the battery. Ed
Ed Pitts is offline   Reply With Quote
Old 03-13-2014, 09:06 AM   #6
Ken Arms
Ken Arms's Avatar
Like GM here is my 12v group 51 batterie box on a 34
Ken Arms is offline   Reply With Quote
Old 03-13-2014, 03:30 PM   #7
Ken Bull
Ken Bull's Avatar
I had a 40 Pickup for 19 years and stock Batt was in engine compartment. I was always charging, cking water level or cleaning acid corrosion off. So when I restored the 36 --not wanting the major inconvienance of going through the floor I got the Optima 3 1/2" wide 6V Batt(Gel=no corrosion) and mounted it by the engine as GM did. Best thing I ever did! If AACA judged ? 2 points off & 3 points off to for Duals and a flafhead V8 is less FUN without DUALS! Enjoy!
Ken Bull is offline   Reply With Quote
