Old 08-03-2013, 10:55 AM   #1
smurph
smurph's Avatar
Question Small Coolant discharge from radiator overflow tube
1935 Cabriolet. New Restoration. Rebuilt engine, new water pumps by Skip Haney. PROBLEM: Small amount of coolant discharges from overflow tube at bottom end. Installed pressure release valve on the tube end as advised. Small amount of coolant still comes out of valve and tube immediately after shutting off engine. Does not appear to come out while driving or idling. Does not overheat, temperature gauge stays at half way or just below. Coolant level about 1/4 inch above radiator core. Radiator was cleaned and tested during restoration.
Any advice on how to stop this from happening would be appreciated. Thanks in advance.
smurph is offline   Reply With Quote
Old 08-03-2013, 11:00 AM   #2
keith oh
keith oh's Avatar
Default Re: Small Coolant discharge from radiator overflow tube
Ask Skip or GM
keith oh is offline   Reply With Quote
Old 08-03-2013, 02:44 PM   #3
flatjack9
flatjack9's Avatar
As long as it doesn't overheat, don't worry about it. When you shut the engine down, you will get a little heat buildup which raises the pressure above the 3 lb limit. If it bothers you, rig up a catch can.
Old 08-03-2013, 03:40 PM   #4
gmc1941
gmc1941's Avatar
Install a over flow tank and after the temperture settles down the over flow will be sucked back into the tank.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 08-03-2013, 07:14 PM   #5
39 STD
39 STD's Avatar
Gmc1841, I have a question regarding installing an overflow tank/tube, that may help smurph & others.
When you install an overflow tank/tube, will the original type cap allow fluid to be sucked back into the radiator? Or do we need a different style cap. ??
God is great, beer is good -----People are crazy
39 STD is offline   Reply With Quote
Old 08-03-2013, 07:34 PM   #6
Ralph Moore
Ralph Moore's Avatar
Smile Re: Small Coolant discharge from radiator overflow tube
As long as it's leaking you know you still have antifreeze.
Ralph Moore is offline   Reply With Quote
Old 08-03-2013, 11:30 PM   #7
G.M.
Flush the pressure valve out it may have dirt in it. You could have a small compression leak, a bottle of Barrs heavy duty aluminum stop leak should take care of that. Also fill your radiator up near the top. G.M.
www.fordcollector.com
Old 08-04-2013, 09:09 AM   #8
Bob/Pa
Bob/Pa's Avatar
Had same problem, installed an overflow tank and it works great. Good luck.
Bob/Pa is offline   Reply With Quote
