Old 07-27-2013, 10:19 PM   #1
smurph
smurph's Avatar
Question Leak less water pumps and 2 blade aluminum fans
I have to replace the water pump on my late 29 Coupe. And while doing so I'll replace the original fan with a 2 blade aluminum. Any opinions on who makes the best leak less water pumps and 2 blade aluminum fans? Thanks in advance for your help.
Smurph
smurph is offline   Reply With Quote
Old 07-27-2013, 11:02 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Leak less water pumps and 2 blade aluminum fans
Snyder's makes the aluminum fans, and all the ones I've checked during the past 3 years have been very good.
As far as a leakless pump, the most reliable and leakless pump is the original design with a good shaft and 2 lead packing rings smeared with grease. I never leaked a drop in 10 years, and last fall I took it apart and installed a rear brass bushing with a seal in the rear of it. This will help to make sure the grease doesn't enter the coolant, and the coolant doesn't enter the grease.
Old 07-27-2013, 11:28 PM   #3
CarlG
CarlG's Avatar
I have a James Rupert pump in my rig. Couldn't ask for a more dependable pump. Not a drop in 3 years since I put it in.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-28-2013, 12:22 AM   #4
Tiny
Tiny's Avatar
I built my own pump. It's really not that hard. Go for it.
I used a Snyders fan. I'm happy with it.
Tiny is offline   Reply With Quote
