Old 02-04-2021, 10:03 AM   #1
jltrade
Default 1951 Ford Victoria Headliner
Does anyone know what color and style this headliner should be? Currently white perforated with gold ribs but would like to replace as original if this is incorrect.
jltrade is offline   Reply With Quote
Old 02-04-2021, 10:57 AM   #2
tubman
tubman's Avatar
Default Re: 1951 Ford Victoria Headliner
If it's any thing like the rest of the '51 line, it depends on the original color of the car. Do you know what that is (or what color you would like it to be)?
Old 02-04-2021, 11:13 AM   #3
mrlaser
mrlaser's Avatar
This is the headliner in my '51 Victoria. It is very close to the one in the Victoria that I had as a teenager. Both cars were two tone green. Unfortunately, it was purchased from the now bankrupt Lebaron Bonney. I hope the pictures help. As Tubman noted. The exterior color dictated the color scheme of the entire interior.
mrlaser is offline   Reply With Quote
Old 02-04-2021, 11:32 AM   #4
mrlaser
mrlaser's Avatar
One other thing to keep in mind is that to replace the headliner you need to remove and replace the three piece rear window. Been there, done that. It is a bit of a challenge.
Old 02-06-2021, 07:26 PM   #5
lonewolf
You can install a headliner and leave the windows in
lonewolf is offline   Reply With Quote
Old 02-08-2021, 12:11 PM   #6
TJ
TJ's Avatar
Not in all cars. Some cars need the glass out as the rubber seal holds the front or back of the headliner in place. Sure you can glue it in place , but it is not correct and doesn't always hold.
Old 02-08-2021, 12:40 PM   #7
mrlaser
mrlaser's Avatar
I was referring only to the 1951 Ford Victoria in the above post. The headliner, in this instance, does in fact need to be installed with the glass removed. On other models, that may not be necessary.
Old 02-08-2021, 03:36 PM   #8
mrlaser
mrlaser's Avatar
I should have said that the correct way includes removing the rear window. I suppose the cloth headliner could be glued but it would be difficult to get the necessary stretch for a nice fit.
Old 10-04-2021, 12:03 AM   #9
Felby
http://www.newstalgapart.com/
Felby is offline   Reply With Quote
