Old 05-09-2021, 11:52 AM   #1
Veeder
Default 41 transmission main shaft corrission
Sorry I'm pounding everyone with so many transfer questions!!
If you could take a look at the pic I would like to know if the amount of corrission will likely pose an issues. I know no corrission is ideal but also don't know what is absolutely unacceptable.
Both the gear and spline are what to reference.
Thks in advance
Bob
Veeder is offline   Reply With Quote
Old 05-09-2021, 05:21 PM   #2
alanwoodieman
Default Re: 41 transmission main shaft corrission
what corrosion? seriously if the slider gear first/reverse slides on it easily then you will be OK
Old 05-09-2021, 06:26 PM   #3
Veeder
Perfect - thanks
